FRporscheman
Joined: 02 Feb 2007 Posts: 16 Location: San Francisco
Posted: Thu Feb 26, 2009 7:22 pm Post subject: VR6 swap... thinking about it |
Hi all, I'm new to this board and I don't even have a 924 yet but I'm convinced I want one and I've already started looking. I'm going to pick up an engine tomorrow which I plan on putting into the 924, it's a 12v VR6.
I'm really experienced with early 944s and 968s. I just rebuild the engine in my 968, along with the steering rack. I understand the 924 has a different engine mounting setup than the 944 (but the 924S is the same as 944). I've never done an engine swap but it seems to me the big obstacles are
1. how to put the engine in so the sump clears the crossmember
2. might need a custom header because the engine is meant for FWD
3. custom motor mount brackets
4. bellhousing? flywheel?
I don't remember what the 924 looks like underneath - is there a crossmember? Or does the engine mount to the frame? My biggest question right now is how I will connect the engine to the torque tube. I don't suppose the 924 or 931 bellhousing will bolt to a vr6 engine? If not, is there a place that makes custom bellhousings? If not, could I weld together a vr6 and 924 bellhousing?
This is a great site and I appreciate all the help! _________________ '93 968
'84 944
82 MB 300td |
FRporscheman
Posted: Fri Feb 27, 2009 5:13 pm Post subject: |
Thanks Stefan. I did try a search before posting but I found very little info and just some references and plans. My brother is a VW guy, I'm a Porsche guy. He is tired of FWD, and I'm tired of timing belts, balance shafts, etc, so we're going to compromise and take the best of both worlds.  _________________ '93 968
'84 944
82 MB 300td |
FSMITH010
Joined: 24 Apr 2009 Posts: 101 Location: Los Angeles, CA
Posted: Tue May 05, 2009 2:06 am Post subject: |
| started yet? |
Posted: Tue May 05, 2009 5:50 am Post subject: |
Just having gotten back from flogging Red all over Portland like Vin Diesel on crack, I can say I will NEVER tire of balance shafts. _________________ Toofah King Bad
chad-tanner
Joined: 23 Mar 2008 Posts: 217 Location: New Madrid,MO
Posted: Tue May 05, 2009 10:22 am Post subject: |
Here is a really great fiero engine swap thread for all the VR6 lovers.Also, this guy is a all brand German car Guru,and may have info on how well the VR6/924 swap would work.
http://www.fiero.nl/forum/Forum3/HTML/000014.html _________________ 77.5 Porsche 924/4.9L cadillac swap
Inspector: These brakes look completely inadequate.
Burt Munro: Well, I'm planning on going, not stopping. |
LS1951
Posted: Wed Jul 08, 2009 3:02 pm Post subject: |
Here's a good write up on a VR6 swap into a 944:
http://www.hybrid9s.com/showthread.php?t=48 _________________ 1987 951- LS1 V8 -Sold
1981 931- Holbert 924H kit -Sold
1980 931- Sold
1965 912- 911 RS replica w/subaru ej20 turbo- Sold
1983 Callaway 944 turbo conversion- Sold
1987 944 Turbo
1977 924 project |
