931 exhaust valves sodium filled?
engineer.white
PostPosted: Tue Jun 30, 2009 9:07 am    Post subject: 931 exhaust valves sodium filled? Reply with quote
Are the 931 exhaust valves sodium filled? If not did anyone make them for the 931?
David
1981 924 turbo/931
1982 924 turbo/931
1986 911 turbo/930
hitbyastick
PostPosted: Tue Jun 30, 2009 10:14 am    Post subject: Reply with quote
Not an expert, but I believe so.
1982 Porsche 924 Turbo
PostPosted: Tue Jun 30, 2009 11:02 am    Post subject: Reply with quote
That is the rumor, but I believe it is largely unsubstantiated at the moment. I'm not aware that anyone has sliced one open.
engineer.white
PostPosted: Tue Jun 30, 2009 11:25 am    Post subject: Reply with quote
Back when I worked on my Saab 99 turbo, the factory manual had disposal directions for the exhaust valves. Drill 1/8" hole axially though the head of the valve into the hollow sodium filled section. Then toss valve in a bucket of water. Did it a few times expecting more excitement, there was only a little bit of bubbling. So anyone have a spare exhaust valve you care to drill a hole in for the sake of science?
David
1981 924 turbo/931
1982 924 turbo/931
1986 911 turbo/930
RC
PostPosted: Sun Jul 05, 2009 2:03 pm    Post subject: Reply with quote
Been done apparently.
In this thread:
http://www.924board.org/viewtopic.php?t=25769&postdays=0&postorder=asc&highlight=valves+sodium+filled&start=0
John Brown wrote:
Quote:
Having heard this more than once, including from my local guru. But could find no documentation of same. So, in the words of my currently favorite educational site: "Hot for Valves decided to investigate".
Cut one apart. No sodium. Stainless and probably other expensive alloys mixed in. But no sodium.
PostPosted: Mon Jul 06, 2009 3:45 pm    Post subject: Reply with quote
John's oversight was to do the experiment at room temp. Valves must be heated for sodium core to liquefy.
John Brown
PostPosted: Tue Jul 07, 2009 4:38 am    Post subject: Reply with quote
I'll readily concede that point. However, I saw no discontinuity in the cross-section.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
Min
PostPosted: Tue Jul 07, 2009 4:55 am    Post subject: Reply with quote
if you still have the cut pieces, you could just heat them with a propane torch
Min
Rich H
PostPosted: Tue Jul 07, 2009 5:22 am    Post subject: Reply with quote
It'll make you jump if you try that.... Chuck it in a bucket of water and it'll fizz.
John Brown
PostPosted: Tue Jul 07, 2009 6:46 am    Post subject: Reply with quote
Am I the only one who finds it remarkable that Porsche would have used sodium valve stems and NOT list same in the tech specs or Turbo repair volume?
John
80 931 - #931 44Cup
