how much does it cost to get A/C conversion done at shop
abdul14
PostPosted: Wed Jun 17, 2009 4:00 am    Post subject: how much does it cost to get A/C conversion done at shop Reply with quote
about how much does it cost to get a/c conversion done at a shop, and does anyone have any shop that they would recommend in the southern, nj philly area
1987 924s (work in progress)
2008 nissan 350z grand touring
2006 suzuki gsx-r 750
View user's profile Send private message AIM Address MSN Messenger
joecitizennn
PostPosted: Wed Jun 17, 2009 12:49 pm    Post subject: Reply with quote
what kind of conversion are you talking about? If it is from r12 to r134, you can sometimes get away with screwing an adapter from a retrofit kit on the low side port and simply filling the system. I did it with my 87S and it is still cold after 2 years with only one refill.
abdul14
PostPosted: Wed Jun 17, 2009 3:24 pm    Post subject: yes converting it from rf 12 to 134 Reply with quote
about how much would it cost, also how to i retrofit an adapter any write ups or advice
abdul14
PostPosted: Wed Jun 17, 2009 4:00 pm    Post subject: Reply with quote
the conversion is from rf12 ro rf134
PostPosted: Wed Jun 17, 2009 8:29 pm    Post subject: Reply with quote
I would not recommend that approach.
The system needs to be fully evacuated of the old oil and refrigerant. ALL of the seals need to be replaced, as well as the receiver dryer. And technically, you should replace the barrier hoses, as the smaller R134a molecule will migrate right through the R12 hoses. If you don't follow this advice, this could be you.
{EDIT}
Around here, reputable shops charge between $200-$400 for a conversion depending on original condition of the overall system.
