is that the torque tube?
CorsePerVita
PostPosted: Sat Jun 06, 2009 7:15 pm    Post subject: is that the torque tube? Reply with quote
started noticing an odd noise. not a grinding noise.... not a horrible noise... just a noise that is, well, faint, but definitely there. i notice is more if i'm letting off the gas with the car in gear. at first i thought "Must be a rotor" but i notice it does it hard on the gas, and off the gas. Maintaining isn't a big deal... and it goes away at highway speed. sounds sort of like a metallic rubbing (like when you have a car up on stands, and turn the wheel). i honestly can't tell where its coming from.
Here's the clencher... if i push in the clutch... it goes away :-/
so it sounds like maybe the bearings in the torque tube. on a scale of 1 to 10 in comparison to doing a timing belt on a 944... where is the torque tube at on replacing the bearings?
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
924guy
PostPosted: Sat Jun 06, 2009 9:23 pm    Post subject: Reply with quote
torque tube possible, so is rear wheel bearings going away...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Sat Jun 06, 2009 10:51 pm    Post subject: Reply with quote
Remember just pressing the clutch while rolling doesn't stop the drivrshaft. You'd need to both press the clutch and put it in neutral..
CorsePerVita
PostPosted: Sun Jun 07, 2009 4:15 am    Post subject: Reply with quote
i should have clarified, yes, that was going downhill in neutral, clutch in.
i'll try a few other things to narrow down.
- 1999 Ducati 900SS
PostPosted: Sun Jun 07, 2009 4:59 am    Post subject: Reply with quote
Clarks-garage.com has a write up on replacing the bearings on a 944. It doesn't seem that bad, but you have to be careful to not damage the bearing carriers.
CorsePerVita
PostPosted: Sun Jun 07, 2009 5:52 am    Post subject: Reply with quote
yeah it looked like a day project
- 1999 Ducati 900SS
mgatlag
PostPosted: Sun Jun 07, 2009 7:19 am    Post subject: Reply with quote
well this one is hitting home with me... I just finished rebuilding my TT in my car this week. I took lots of pics along the way and am going to add a how-to on the site. If you want, PM me and I'll talk to you a little about what I found while doing my rebuild. There are DEFINITELY things that are on the NOT to-do list. I learned the hard way with the carriers. Let me know if I can help.
Michael
'77 1/2 924 N/A- 5 speed Audi box
'04 Ford Taurus - gone!!
'92 Jeep Cherokee Laredo - gone!!
Porsche... better than tea with Miss McGill
(Slap Shot)
CorsePerVita
PostPosted: Sun Jun 07, 2009 8:39 am    Post subject: Reply with quote
was yours doing the described above on yours?
- 1999 Ducati 900SS
mgatlag
PostPosted: Mon Jun 08, 2009 7:15 am    Post subject: Reply with quote
yup sounds like the same noises I heard.
Michael
(Slap Shot)
benlg81
PostPosted: Tue Jun 09, 2009 6:47 pm    Post subject: Reply with quote
same noise that i have been having issues with in mine what is the issue at fault then? and how easy for a novice in the garage?
joecitizennn
PostPosted: Wed Jun 10, 2009 12:05 am    Post subject: Reply with quote
With the car sitting still in neutral and the clutch out can you hear the noise? In this condition the only things spinning are the clutch, driveshaft and tranny input shaft. If you dont hear the noise it is probably something besides the driveshaft tube. However, it is always possible that driveshaft distortion under a heavy load causes the bearings to make noise that they dont make just sitting still. That said, in my experience, if you have dry or damaged bearings they will make some kind of noise even under no load.
If you only hear the sound with the car in motion it could be many things in the rear drive train.
joecitizennn
PostPosted: Wed Jun 10, 2009 1:21 am    Post subject: Reply with quote
If you are thinking of removing the driveshaft tube you might as well throw a clutch kit in while you are in there. A fast man with a lift and tranny jack who knows what he is doing will be just over a half-day removing and installing a torque tube. If you dont have a lift or tranny jack or air tools dont plan on getting it done in a whole day. That is if you have another tube to install. If you are rebuilding the tube your car is going to be down a while.
A transmission being pretty easy to pull, I would try this test first. When you have a day free pull your tranny out. It is not that bad, just a couple bellhousing bolts, trany mounts, shift rod, drive coupler, and two CV shafts. Tranny jack would help, but a big floor jack and maybe a friend will do. With the transmission removed, use a stick to hold the clutch pedal down and crawl under the car and spin the driveshaft by hand. Do the bearings sound smooth? Is there a roar? THey may be dry. Is there binding? There may be failed bearings. Pull back and fourth on the shaft, does it move? It should not. If it does bearing insulators and bushings may be gone. Try to wiggle the shaft in all directions feeling for play, then slowly turn it while pushing or pulling hard on it feeling for binding spots or roughness. If the shaft spins smoothly and is solid in the tube you can probably rule it out as a problem.
Remember, your clutch disc will be ratteling on the other end of the shaft as you wiggle it around and spin it, dont confuse that as bearing noise. Start up the car and let the clutch out and listen to the whirr of the bearings in the shaft. There should only be a whisper.
With your tranny out, you can spin the input and output shafts of the transmission feeling for play or roughness, and you can also turn you cv shafts and wheels by hand. Taking the system apart in this manner nicely isolates possible problem areas eliminating confusion
