Brake upgraders for 924 n/a -79?
Goto page Previous  1, 2
FSMITH010
PostPosted: Sat May 16, 2009 9:37 am    Post subject: Reply with quote
is this for the 4 lug or 5 lug? Not sure if there is a rotor size difference. Assuming there is.
CorsePerVita
PostPosted: Sun May 17, 2009 9:38 am    Post subject: Reply with quote
The drums on my 77' are pretty beat to hell. One side won't even come off which is why it's "sticking" i found.
So i'm at the point where i'm ready to replace it, or upgrade it (to get rid of it entirely).
Any recommendations? I was talking to stefan and he said if i went with the 944 setup i'd have to swap over the suspension too? I like my brakes on my 944. I could see that being pretty sweet on the 924. Mostly for the purposes of less maintenance and ease of changing pads and maintenance would be my main reason longterm as frequent brakeshoe adjustments are annoying to me lol. I hate hate hate hate working on drum brakes.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Sun May 17, 2009 11:02 am    Post subject: Reply with quote
Start here: Illustrated Guide to 5-lug Conversions
For the full story on how it impacts choices for suspension, see the suspension section of the performance upgrade thread.
jessy1984
PostPosted: Thu Jun 18, 2009 6:34 am    Post subject: Reply with quote
jurasT wrote:
For an easy upgrade you can install audi b3/vw passat calipers - 54mm piston diameter (compared to original 48mm ) and brake carrier is much smarter than original. And they are a bolt on upgrade.
Front is slightly better now but rear is still
http://img106.imageshack.us/my.php?image=dsc090546wq.jpg
http://img507.imageshack.us/my.php?image=dsc090257ls.jpg
And without pads:
http://img360.imageshack.us/my.php?image=DSCN8493.jpg
http://img360.imageshack.us/my.php?image=DSCN8494.jpg
dous anyone know from what car exactly the brake carriers come from (from what years ) and what fits a 924 i have bigger pistons for the rear they are front pistons from a vw bug 22mm a 924 has original 19mm these fit but off course i need bigger pistons in the front to
mcadam1121
PostPosted: Fri Jun 19, 2009 1:15 pm    Post subject: Reply with quote
when you convert from the four lug to the 5 lug what all do you need from the 944
also does the 944 use studs or bolts to hold teh wheel on like the four bolts do
im doin an engine swap so i will prolly want to get the 951 brakes rite
The Ginger
77 porsche 924 Martini
PostPosted: Fri Jun 19, 2009 9:03 pm    Post subject: Reply with quote
Dude, look two posts above your own and follow the link there. All of your questions answered, even with diagrams and other cross references.
Goldwolf
PostPosted: Thu Mar 17, 2022 11:31 pm    Post subject: Reply with quote
I'm busy resurrecting old threads.
I ordered Centric brand(PN# 14133030) 1991 Passat calipers yesterday for $36 each from rockauto. I will measure the mounting holes and post a pic.
The clips and pins for the old brakes cost more than the new calipers.
1981 Weissach Edition #179
Goldwolf
PostPosted: Sun Mar 20, 2022 2:02 am    Post subject: Reply with quote
Measurements seem correct so far.
Riggard
PostPosted: Sun Mar 20, 2022 5:35 am    Post subject: Reply with quote
sounds good, would be awesome to see if it works, please keep us posted!
Goldwolf
PostPosted: Sun Mar 20, 2022 8:27 am    Post subject: Reply with quote
This is a crap pic but it gives me some hope. Looks to me to be 106mm and I am about 95% sure the bolt holes will line up. What I don't know is if the thing will line up over the rotor etc... I am a little gun shy on ripping it all apart. I don't think the brakes lines have ever been replaced and I wanted to make sure I had a working set of originals. I WILL make sure to post the outcome. This would keep the 4 lug alive for a long time. In my case the spider web wheels have to remain for the Weissach.
Also gathering front suspension parts to get that refreshed. This is the final mechanical push for me.
The dang brake hardware, clips and pins cost $35 at best. New Passat calipers and pads delivered is $100. Pads are $15!
PostPosted: Sun Mar 20, 2022 5:23 pm    Post subject: Reply with quote
Do they have different piston diameter as mentioned above in the old posts?
safe
PostPosted: Wed Mar 23, 2022 1:41 am    Post subject: Reply with quote
Pretty useless upgrade to only upgrade calipers....
If someone has a decent upgrade to ventilated disks and preferably rear disk brakes to while keeping the 4 lug pattern I would be interested.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
Goldwolf
PostPosted: Wed Mar 23, 2022 3:28 am    Post subject: Reply with quote
This piston is larger, I think 55 compared to stock 48, I will measure it.
Page 2 of 2
