Electrical problem
doiron_dancer75
PostPosted: Thu May 14, 2009 11:07 pm    Post subject: Electrical problem Reply with quote
So this past week we had to change my ignition switch in the 924. But around a week before we changed it a wire from my coil to the fuse box burned. The wire may have burned further in the fuse box, but the fuses in front of it seem fine. Does anyone know what would cause that wire to catch fire? Any help would be great.
Thanks
huckster
PostPosted: Fri May 15, 2009 3:56 am    Post subject: Reply with quote
I do not have any specific expertize with that wire but I had enough electrical gremlins that I took my fuse box apart and found lots of shorts due to rusting inside. Allso the grounds behind the fusebox will cause lots of problems if they are dirty.
77.5 project car have never driven. burgundy
79 parts car sea foam. blue new clutch and shifter bushings
79 driver yellow new shocks water pump shifter bushings
96 ford escort sw
PostPosted: Fri May 15, 2009 3:59 am    Post subject: Reply with quote
High resistance due to aged wires can cause heat, enough to melt the shielding and even cause it to smoke. Or a short to ground prior to the fuse.
doiron_dancer75
PostPosted: Fri May 15, 2009 10:04 am    Post subject: Reply with quote
Thank you, my father will be checking those suggestions tomorrow when he's done work. I'll post tomorrow with any further info.
PostPosted: Fri May 15, 2009 2:33 pm    Post subject: Reply with quote
Your car has one or two resistor bolted to the sides of the coil (depends on the model year of the car). Could be a coil to resistor wire rubbed itself bare, and shorted to the coil mounting bracket or bolts and nuts.
That's where I would start looking.
doiron_dancer75
PostPosted: Fri May 15, 2009 11:57 pm    Post subject: Reply with quote
The car is a 1979 924. I'll get my father to check it out as soon as he gets home from work today.
Scorpio
PostPosted: Sat May 16, 2009 9:19 am    Post subject: Reply with quote
check youre using correct fuses...mine were all mixed up from PO...fuse should be the first thing to melt in a circuit unless a higher then normal fuse is being used as a bandaid
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
doiron_dancer75
PostPosted: Sat May 16, 2009 11:55 pm    Post subject: Reply with quote
Ok so me and my dad checked everything out yesterday, turns out my alternator let go. We had it rebuilt last summer, and I guess whenever it let go that one wire burned.
John Brown
PostPosted: Mon May 18, 2009 4:27 am    Post subject: Reply with quote
Somewhere, years ago?, I posted pictures of, I think, Plug A on the back of the fuse box. A17 (??) had over the years burnt out the plastic surrounding that pin simply from the continued heat at the junction. And I saw 2 or 3 fuse boxes like that. May be wrong about the exact pin number. Anyway, A17 is the power to the coil.
Point being that there are several circuits which are marginal especially over time. Heat begets corrosion which begets more heat .... Or is it corrosion begets heat which begets ....
John
80 931 - #931 44Cup
99 Escalade - tows track cars
