Kevlar timing belt
dash16
PostPosted: Tue May 05, 2009 7:47 am    Post subject: Kevlar timing belt Reply with quote
Anyone ever seen these belts before?
http://www.rennbay.com/timing-belt-kit-kevlar-racing-belt-p-164.html
Is this belt suitable for daily driving?
And perhaps extended period before the belt needs to be changed?
It says its for racing but its also apparently 3x stronger than the OEM timing belt.
If you have personal experience with these belts, please let us know.
Thanks
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
PostPosted: Tue May 05, 2009 7:49 am    Post subject: Reply with quote
Very interesting. . .I may be using these on my next FOES. Of course, with the material change, you can probably toss the factory tension specs out the window.
PostPosted: Tue May 05, 2009 9:06 am    Post subject: Reply with quote
Looks like the balance shaft belt is a standard Gates.
1987924s
PostPosted: Wed May 06, 2009 9:29 am    Post subject: Reply with quote
balance shaft isnt the biggest problem, I am very interested and since I have not droped the motors back in yet?????????
have to put aside some of the next paycheck
Scott Martin
1987 924S Red 5spd
2010 Fusion sport
JayZzzz4
PostPosted: Wed May 06, 2009 10:32 am    Post subject: Reply with quote
I came across this a few weeks ago on rennlist. Some say it's not worth the extra money for the belt when you have to replace the water pump and pulleys every number of miles. And there is No guarantee if it does break they(the company making the product) will pay for the damage.
How many miles would you drive it before replacing it?
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/497293-on-timing-and-balance-belt-life.html
White 1987 Porsche 924S manual
dash16
PostPosted: Sun May 24, 2009 1:14 pm    Post subject: Reply with quote
I am under the impression that you may re-use the belts when changing the WP and pulleys if the belt has yet to reach the end of its lifespan.
interested in the kevlar belts to prepare for the worst case senario. If you got the money, why not?
STUTTGART PREVAILS
bcblase
PostPosted: Wed May 27, 2009 12:59 pm    Post subject: Reply with quote
Kevlar or Schmevlar... or whatever...
If your water pump seizes up, it doesn't matter what the belt is made of...you are screwed, and your valves are bent.
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
PostPosted: Wed May 27, 2009 3:08 pm    Post subject: Reply with quote
Also doesn't matter if the balance shaft belt is still rubber, because when it breaks, the pieces will tangle the timing belt, and the odds are the timing belt is going to get thrown off with the predicable result.
