Posted: Mon Apr 20, 2009 5:01 am Post subject: EGT on N/A? |
Since the A/F ratio as a large influence on the exhaust temperature, I figure it would be a good tuning and monitoring tool.
My problem is that I don’t have a clue where this temperature should be. I’m planning on mounting the probe (clamp style)
about 2-3” from the head on the #2 runner, it’s the easiest one to access without taking the engine out.
Anyone know what is the proper EGT reading for the 924 N/A?
Anyone as one? What are your data?
Any suggestion?
Thanks _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Rich H
Posted: Mon Apr 20, 2009 5:31 am Post subject: |
Yes, use a lambda probe? _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Mon Apr 20, 2009 5:34 am Post subject: |
What do you meen by lambda? O2 sensor? _________________ 1976 924 N/A ROW SOLD
1980 931S
Rich H
Posted: Mon Apr 20, 2009 5:44 am Post subject: |
I know nothing about EGT but a wide band lambda probe will give you AFR directly and in (virtual) real time on a dash gauge.
However.... Without EFI you can basically do cock all about it really, BTDT (and fitted EFI ) _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Mon Apr 20, 2009 6:24 am Post subject: |
I’m just trying to find a cheap and good way to tune and monitor the car.
Wideband O2 is far from cheap.
The car run great but I just don’t know if it’s running too lean or not and I don’t want to pull the spark plug all the time.
I’m also planning to have a low cost O2 narrowband. Both together should give me a good diagnose at a good price. _________________ 1976 924 N/A ROW SOLD
1980 931S
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Mon Apr 20, 2009 10:05 am Post subject: |
| 924-76 wrote: | The car run great but I just don’t know if it’s running too lean or not and I don’t want to pull the spark plug all the time.
I’m also planning to have a low cost O2 narrowband. Both together should give me a good diagnose at a good price. |
Just remember that NB will tell you if you a lean or rich - but it won't tell you by how much you are off stoich.
Have you looked at the JAW project for a DIY WB sensor?
G. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Mon Apr 20, 2009 9:00 pm Post subject: |
The JAW project look cool but I would not trust my self to do something like that;
I just don’t have any experience and knowledge in that kind of stuff.
1980 931S
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1425 Location: Washington DC area
Posted: Tue Apr 21, 2009 1:01 am Post subject: |
Part of the problem with an EGT probe is the location. The further from the valve face, the cooler (relative) the gasses. Another problem with the EGT is that it reacts slowly so you will need multiple seconds of WOT to get a good reading on the guage. It's useless for cruising at part throttle. I used to get readings in the 1200 to 1250 degree range at 15 inches from the valve face for an ideal mixture. If the temps got over that, I was running leaner that I liked. On a cool off lap, the guage would read around 600 degrees.
Go with an O2 sensor...
Chuck |
Posted: Tue Apr 21, 2009 4:16 am Post subject: |
Thanks for the info. _________________ 1976 924 N/A ROW SOLD
1980 931S
flosho
Posted: Tue Apr 21, 2009 4:47 am Post subject: |
A quality pyrometer(EGT) will cost you $150+ and a quality wideband air/fuel gauge will only be another $50-$75 more and much more understandable.
EGT is a good tuning tool for people that are REALLY concerned about tweaking every last bit of the engine.
For most street car tuners and more daily driver/tinkerers.. a wideband gauge is a better solution.
I recommend the AEM UEGO.. It's all contained within itself, standard 2-1/16" gauge face, with interchangeable colors/bezel.
If you don't want a round gauge, the PLX brand would be a good device for the glove box or center console(although harder to see).
If you are really looking for a lower cost unit, the Innovate LC-1 wideband kit(no gauge, need laptop) is only $170 and works with a lot of other tuning equipment/emu but also stand-alone on its own, but like I mentioned, there is no gauge at the lower price point. _________________ [This Space For Rent] |
