Boostsideways
Joined: 11 Feb 2009 Posts: 100 Location: CT, Southbury
Posted: Mon Apr 20, 2009 7:23 am Post subject: Hmm.. fishy.. maybe this is it? |
Ok, so i've tested everything. Cleaned everything up, made sure all my connections were good, nothing was loose, everything is good to go, my Crank shaft sensor is on tight.. Still no spark, a friend thought he heard clicking coming from my ignition coil, so i changed that and tried it again, nothin, but i still hear the ticking, i put my ear close and im pretty sure its coming from the distrub cap.. so I pop it off and right there my rotating head or whatever it is (the rotar, you know that sends the spark off to the plugs) wasn't at top dead center.. think maybe it just got knocked far off track and i need to re-top dead center it or make sure it stops on the first ignition plate.. Does this sound like a possible problem? Or does it just stop where ever inside there? An' if not, how to fix? Thanks faithful 924 board fans! _________________ Just wait 'till my turbo starts firin' the RPM LZR!
My car= Porsche 924 turbo, 1982. |
BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Mon Apr 20, 2009 9:32 am Post subject: |
Yea thats kinda important as thats your timing. Your car was running at some point right?
If so, since then have you pulled your distributor out?
If so, then you didnt put it in at TDC. so you will have to pull it out and redo it.
If not, then your timing is off and you won't have to pull the distributor out to fix it. You just need to loosen the bolt holding it down and turn it to the correct timing. You will need a timing light to do this. _________________ 1980 924 NA
1982 931 |
Posted: Mon Apr 20, 2009 9:57 am Post subject: Re: Hmm.. fishy.. maybe this is it? |
| Boostsideways wrote: | | ? Or does it just stop where ever inside there? |
Yes - it, along with the rest of the engine, ends up at a random position every time the engine is shut down. If the distributor is both installed and set correctly, the rotor should point to #1's cap post if you have the cam and crankshaft TDC marks lined-up. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Boostsideways
Posted: Mon Apr 20, 2009 9:58 am Post subject: |
Failed.. I really can't figure this out.. then my battery started dieing and i just got fusterated an' gave up.. I think i f-ed it all up to 'cause instead of just trying to spin the distrib first i took the cap off too to try an crank the thing onto top dead center.. god im a idiot.. this is a big timing mess.. Im screwed. thanks for help guys _________________ Just wait 'till my turbo starts firin' the RPM LZR!
BionicBalls
Posted: Mon Apr 20, 2009 2:59 pm Post subject: |
| Quote: | | Yes - it, along with the rest of the engine, ends up at a random position every time the engine is shut down. |
LOL I about pissed myself. _________________ 1980 924 NA
1982 931 |
Boostsideways
Posted: Mon Apr 20, 2009 10:17 pm Post subject: |
You sit there and laugh but now my car is worse off then before =p I guess its alright tho 'cause she did need a timing and the crank sensor or wheatever general area neeeds work cause the car idled weird and died coming off highways _________________ Just wait 'till my turbo starts firin' the RPM LZR!
BionicBalls
Posted: Tue Apr 21, 2009 12:01 am Post subject: |
well take it to a mechanic and get the timing adjusted. Its not expensive.
I know the 44's have crank reference sensors, but i didn't think that the 24's did. Its mechanical injection so I can't see as they would need one. _________________ 1980 924 NA
1982 931 |
Posted: Tue Apr 21, 2009 2:09 am Post subject: |
He has a series II 931 with DITC.
in order to get the car to TDC you have to use a socket and ratchet and manually turn over the engine! You will never get it where you want it with the starter!!!!
If you dont have spark then check the connector at the DITC box. _________________ 3 928s, |
