Spring Tensioner, Engine Code Location
PostPosted: Mon Apr 13, 2009 8:46 am    Post subject: Spring Tensioner, Engine Code Location Reply with quote
Shouldn't every US 2.5 have a spring (so called "automatic") timing belt tensioner?
And on a related note, where is the 2.5 engine code stamped?
Can you guess why I am asking?
PostPosted: Mon Apr 13, 2009 11:07 am    Post subject: Reply with quote
No, all 944 got the spring belt tensioner for the 87 model year along with the extra 11hp (higher cr pistons).
The 87 924S started getting the spring tensioner around the end of the model year (after June 87?).
I think Porsche used up the blocks that were manufactured for use without the spring tensioner on the 87 924S, and started putting the engines with spring belt tensioners in, after the older design blocks were used up.
Something like what they did with the MPG gauges, since some 924S got no MPG gauge parts, while others got some parts (not all), and a few actually got working MPG gauges.
Engine type number and serial numbers are located on a flat spot on the top rear of the engine. Below the flywheel sensor connector block on 87 and earlier blocks. On 88 and later blocks, the serial and type number are on the right side of the block.
My 924S didn't get a working MPG gauge or a spring belt tensioner.
joecitizennn
PostPosted: Tue Apr 21, 2009 1:40 pm    Post subject: Reply with quote
I bought a red 1987 924S parts car that did not have a spring belt tensioner. Till that point I thought they all did. Hmm, lets see, that engine is still sitting under a tobacco barn in NC with the head removed. Probably home to some mice now.
jrrhdmust
PostPosted: Tue Apr 21, 2009 11:38 pm    Post subject: Reply with quote
So can you look at the front, balance covers off, and tell whether or not is has the spring tensioner?
67 Mercury Cougar XR7 under Restoration
71 VW Superbeetle Completed Resto 11/07
73 Mustang Mach 1 10 Year old restoration
PostPosted: Wed Apr 22, 2009 12:26 am    Post subject: Reply with quote
Oh yes. Timing tensioner will either be a small subtle roller with offset hole or large contraption. You can't miss it.
joecitizennn
PostPosted: Wed Apr 22, 2009 3:39 am    Post subject: Reply with quote
As I remember, Clarks garage has some nice diagrams of all the timing belt setups on the 4 cyl water cooled porsche engines. www.clarksgarage.com
jrrhdmust
PostPosted: Wed Apr 22, 2009 4:07 am    Post subject: Reply with quote
Cool thanks that is what I thought.
