Front sway bar larger than 24mm
Browar
PostPosted: Sun Apr 05, 2009 6:20 pm    Post subject: Front sway bar larger than 24mm Reply with quote
Hi,
I would like to install in 924 S front sway bar bigger than 24mm. End of sway bar on 25,5 , 26,8 and 30mm is thicker than on smaller ones (20-24mm).
How to do this?
Browar
eS
924 S `87
NBRettie18
PostPosted: Sun Apr 05, 2009 7:43 pm    Post subject: Reply with quote
you have to hone out the rubber bushings to fit the larger sway bar, it is time consuming but it can be done
1987 924S - MO30 30/19 - Yellows all around
PostPosted: Mon Apr 06, 2009 12:44 am    Post subject: Reply with quote
Just took a moment on my car. . .reamed it out a bit with a large drill bit, applied some lithium lube, and it went together easily.
PostPosted: Mon Apr 06, 2009 3:40 am    Post subject: Reply with quote
Or get new bushings. Upgrade to poly or delrin maybe?
