tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Wed Mar 11, 2009 1:28 am Post subject: Sometimes surprises are good! |
Hey I just bought an engine short block, head and turbocharger from a guy.
Here's the story. He rebuilt the engine for like a package price of $12K along with a new turbocharger through Porsche. He took it out for a few spins and the car made a bad noise and then was running on three cylinders. So he removed the engine and took the car to a scrap yard. He's had quite a saga with this car and he just got pissed off and scrapped it. I kind of understand where he was coming from... as we all do.
I bought the engine for $125 as a rebuild 'project' but here's the skinny:
1. A mechanic I do trust says the short block is perfect. All four cylinders are in good shape - no honing necessary - leave the pistons and replace the #2 piston with rings. Sound ok? He's suggesting I use the same rod.
2. Head has some damage and a bit of a warp but a shave should do the trick. No evidence of bent valves yet. I'll take them out and inspect later on. Question: There's some pock marks from whatever was banging around in Cylinder 2 - what to do with those? There aren't many (a dozen) and they're small - maybe 1-2 mm. Even the head gasket was perfect.
3. The turbo is absolutely freaking perfect. There is zero axial or radial play and it spins beautifully - I've handled a few of these over the years and it's better than any of the rebuilds I've seen. I literally reefed on the the axle and couldn't detect ANY play whatsoever. So I'll rebuild this turbo instead and replace the seals - it's been out of commission since 2004 so the seals might be a bit dry.
Anyway, it's the best $125 I've ever spent. Very happy today! I've written a bit with Ideola and there were some excellent suggestions on the table I'm going to use. Any suggestions appreciated. I'm trying to do this for under $1000. I'll keep this thread to post results as they happen. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Posted: Wed Mar 11, 2009 2:09 am Post subject: |
I wouldn't rebuild the turbo. Turbo seals are all metal, and don't dry out.
There is a high-temp rubbery (viton?) o-ring at the oil inlet, but that's at the outside and not part of a "turbo rebuild". _________________ "..it's made in Germany. You know the Germans always make good stuff."
Joined: 29 Jul 2001 Posts: 9135 Location: Royal Oak, MI, USA
Posted: Wed Mar 11, 2009 2:11 am Post subject: Re: Sometimes surprises are good! |
| tuurbo wrote: | Anyway, it's the best $125 I've ever spent. Very happy today! I've written a bit with Ideola and there were some excellent suggestions on the table I'm going to use. Any suggestions appreciated. I'm trying to do this for under $1000. I'll keep this thread to post results as they happen. |
Sounds cool and all... but... careful talking to ideola... he's a sick, twisted man with too many projects and he'll lead you down the path of all that is dark and unholy!
LOL
Next thing you know, you'll be scouring southern NJ for every forlorn waterpumper to drag back home and part out...  _________________ Vaughan Scott
ic932
Posted: Wed Mar 11, 2009 2:22 am Post subject: Re: Sometimes surprises are good! |
| tuurbo wrote: | Hey I just bought an engine short block, head and turbocharger from a guy.
Wow, like your avatar thing...you've landed on all four feet! Re-buil your car an don't over-analize lol |
Posted: Wed Mar 11, 2009 3:10 am Post subject: Re: Sometimes surprises are good! |
| 924RACR wrote: | careful talking to ideola... he's a sick, twisted man with too many projects and he'll lead you down the path of all that is dark and unholy!  |
Bwahahahahahahah!
Stare into my little beady eyes You will give me one-BILLYUN toofah parts
Bwahahahahahahah! _________________ erstwhile owner of just about every 924 variant ever made |
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1425 Location: Washington DC area
Posted: Thu Mar 12, 2009 3:23 am Post subject: |
Tuurbo,
I have a set of 931 pistons that you can have for your rebuild. I only need NA stuff. Challenge others to pony up parts and keep your costs way down.
Regards,
Chuck |
Posted: Thu Mar 12, 2009 4:36 am Post subject: |
Gah! Have? Dibs if tuurbo declines. _________________ Toofah King Bad
tuurbo
Posted: Thu Mar 12, 2009 6:32 am Post subject: |
Thanks very much for the offer Chuck - I've got what I think are the offset 7.5:1 compression pistons here so I think I'm ok! Cylinder and piston are measuring out at 8.65 mm using a tape measure (can't find my calipers yet - maybe a touch of measurement error there on my part). But thanks that's a very generous offer. I've got these two spares and I cleaned one of them up and it should be good to go because when I put it into the cylinder, crown first, it fits with about 1.0 mm of play from side to side - should be ok. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Posted: Thu Mar 12, 2009 10:39 am Post subject: |
| tuurbo wrote: | | when I put it into the cylinder, crown first, it fits with about 1.0 mm of play from side to side - |
I'm sure you'd be re-measuring with a good caliper, micrometer and/or feeler gauge before proceeding - but a full 1mm difference between piston and cylinder is way excessive. Should be more like 0.06mm difference, right?
Something like a 3rd oversize cylinder bore, with standard size pistons would leave about 1mm play. _________________ "..it's made in Germany. You know the Germans always make good stuff."
tuurbo
Posted: Thu Mar 12, 2009 1:32 pm Post subject: |
I'm confused. Probably need to clean these up.
Ok cylinder 86.98
Measured 14 mm from piston bottom edge perpendicular to the hinge as per Manual
1. Spare piston #1 86.44
2. Spare piston #2 86.95
3. Spare piston #3 86.42
The removed destroyed piston says ++++++ 86V53 A R011 inside it but it seems to measure out at 86.36 at the crown, 86.94 at the bottom.
Lots of dirt though - gonna clean it up and measure again.
Man they're hard to measure up consistently! Do you take an average of all your measures or what? lol
I might have a 2nd oversize cylinder there - I didn't think there were many of those out there.
Note:
Measured at crown
1. Spare piston #1 diameter 86.09; ++++ 86V53 offset dish
2. Spare piston #2 diameter 86.42; ++++++ 86V53 non-offset dish (3rd oversize I believe)
3. Spare piston #3 diameter 85.8; ++++ 86V53 offset dish _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock.
Posted: Thu Mar 12, 2009 1:56 pm Post subject: |
The Haynes manual gives standard and oversize piston and cylinder sizes on pg. 49.
(Correct the misprints near the bottom of that - where it says "86.45" and "86.46" for 3rd oversize piston diameter, obviously change them to "87.45" and "87.46".) _________________ "..it's made in Germany. You know the Germans always make good stuff."
tuurbo
Posted: Thu Mar 12, 2009 2:06 pm Post subject: |
Thanks Smoothie - I think I've got 2nd oversize. But I need to clean more and take my time. Hmm. 2nd or 3rd oversize changes things a bit.
Chuck do you, by some small chance, have a 2nd oversize with the dish offset so it's a 7.5:1 compression (old style)? If not that's ok I can probably use the higher compression piston in that #2 spot if you don't. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Posted: Thu Mar 12, 2009 5:03 pm Post subject: |
it doesnt matter if the seals at dry.
They are assembled that way.
Install the turbo without messing with it. _________________ 3 928s, |
Fifty50Plus
Posted: Fri Mar 13, 2009 1:30 am Post subject: |
Tuurbo,
I won't be able to check sizes until weekend. I sent you a PM.
Chuck |
Posted: Fri Mar 13, 2009 2:12 am Post subject: |
| Quote: | | I can probably use the higher compression piston in that #2 spot if you don't |
Perhaps I'm misunderstanding, but you can't mix low and high-compression pistons...all of one or the other |
