Rear shoes adjust
flyguy
PostPosted: Tue Feb 24, 2009 3:26 pm    Post subject: Rear shoes adjust Reply with quote
Searched on here for my answer, but only answe rI found was for a 1980 NA 924.
How do you adjust the rear brake shoes on a 1977 NA 924?
JUst had new MC put in and system bled. Brakes now work worse than before (foot to floor, still only giving %60 braking power AND E-brake now doesn't seem to hold)
Seems like the rear brakes need to be tightened but haven't found anything on it yet, any help would be appreciated!
PostPosted: Tue Feb 24, 2009 4:44 pm    Post subject: Reply with quote
There is two star adjusters in the bottom of the backing plate.
Probably find a rubber plug covering the access hole.
I find the easiest method is to have the rear end up on stands, out of gear with handbrake off. Adjust each star evenly until the wheel starts to bind then back off a little.
flyguy
PostPosted: Wed Feb 25, 2009 3:55 am    Post subject: Reply with quote
Can you elaborate on this procedure abit more in detail, if you can?
From the way it wounds, i just take the wheel off, and using the inspection holes move the shoes closer in, no?
PostPosted: Wed Feb 25, 2009 5:14 am    Post subject: Reply with quote
It's been answered in your other thread on this topic.
78 924 NA
5-lug
datatrain
PostPosted: Wed Feb 25, 2009 5:46 am    Post subject: Reply with quote
I didn't see your other thread.
On the back of the brake plate are 2 slotted holes. You get to them from under the car. Leave the wheels on. Use a screwdriver to turn the star wheel you'll find in the hole. One way tightens the other loosens. There is one star for each shoe. Adjust them both as described above. Spin the wheel as you turn the star. Same for the other back wheel.
That's all.
DAve
'78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
flyguy
PostPosted: Wed Feb 25, 2009 7:38 am    Post subject: Reply with quote
Damn. The adjusters are ceased :S
Now gotta figure out what to do.
I still get better brake pressure after i pump it a few times, and its not air or water. The rear drums/shows SHOULD be replaced especially if ceased.
So here is my dilemma. Should I get new drum/shoes OR switch to the brake caliper and pad conversion?
Thoughts? Answers? Sales? References?
PostPosted: Wed Feb 25, 2009 7:45 am    Post subject: Reply with quote
Perhaps you should pull the drum and inspect the adjusters before ceasing your inquiry. You can probably knock them loose, clean and lightly lube them, and get them back into service.
flyguy
PostPosted: Wed Feb 25, 2009 7:47 am    Post subject: Reply with quote
My issue though is that if I can't, or if one of the parts becomes broken or unusable when I open them up i'd rather have everything already at hand, as this is my daily vehicle.
Also, since this is a long term restoration project, maybe replacing the rear brakes would be a better long term idea.
tuurbo
PostPosted: Wed Feb 25, 2009 7:48 am    Post subject: Reply with quote
The drum shoes are pretty cheap. I use the 4 bolt drum/disc combination and it's fine for street driving. Cheap to maintain - I'd go with the 5 bolt conversion if you want to seriously upgrade the car to autocross or DE day performance requirements. Else, just use the stock setup.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
Rich H
PostPosted: Wed Feb 25, 2009 7:58 am    Post subject: Reply with quote
The mechanism is very simple.
The drums/shoes can be assessed through the outermost holes, you can see the thickness of the drum and shoe material there.
If it all looks OK then as a minimum get a fitting kit, they are always manky as hell. Shoes are cheap too. If the adjusters are stuck then put a bolt in and tighten it up. The adjuster will pop out - probably.
Or you can get the whole lot, backing plates, cylinders, shoes, fittings and new adjusters then it'll out live you
PostPosted: Wed Feb 25, 2009 8:04 am    Post subject: Reply with quote
And if you drive hard, the frequent adjustments will outlive your patience.
Rich H
PostPosted: Wed Feb 25, 2009 8:07 am    Post subject: Reply with quote
That is true...
tuurbo
PostPosted: Wed Feb 25, 2009 8:27 am    Post subject: Reply with quote
For my purposes I've defined this as a couple of trips where you experience fade - probably five or so hard brake episodes each trip will do it. In my case such trips have meant readjustment.
flyguy
PostPosted: Wed Feb 25, 2009 12:44 pm    Post subject: Reply with quote
What do you mean by this process? there is still enough meat on the shoes, and maybe just to add some detail, i get good braking after i pump it about 5 times.
datatrain
PostPosted: Wed Feb 25, 2009 2:02 pm    Post subject: Bleed 'em Reply with quote
Sound as though you need to do a serious brake bleeding. Pumping can be indicative of air in the lines. You'll need someone on the pedal to pump. Open the bleed valve and let 'er go. Close and pump and do it again a couple more times. Be sure to top up the Master cylinder after a couple of times. I'd expect you'll see a big improvement.
I don't think it matters if you folllow the sequence. Just get the air out.
Oh, and be sure to use fresh brake fluid to top the master cylinder. Don't shake the can and keep it off the paint.
DAve
Mint '92 318i BMW
VE7HFR
