moped
Posted: Fri Feb 13, 2009 12:01 pm Post subject: Blew out the engine of a 79 924 - rebuild or replace? |
During a road trip between Memphis and Atlanta, I had an oil leak, and my engine (1979 924) seized up. I was surprised, since I got it back from a mechanic 1 week before, after a full inspection.
The Porsche dealership in Atlanta looked at the engine for 5 min, and said I blew a rod, and the engine is completely dead. The oil was completely gone, and the engine was bone dry. I called some mechanics around town, and they think they can fix it.
So I'm wondering - is it worth the cost of an engine rebuild? Or should I try to find a replacement engine? |
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Fri Feb 13, 2009 12:37 pm Post subject: |
main bearings are no longer available, so i dont know if you can even get the parts to rebuild it... _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
Eturbo924
Joined: 09 Nov 2002 Posts: 2212 Location: Londonderry NH
Posted: Fri Feb 13, 2009 2:18 pm Post subject: |
Well depends... how much money are you willing to spend?
I have a good 1980 motor that will cost you a lot less. Though... I am in NH so it would be a road trip to come and buy it from me.
Eturbo924@yahoo.com
Eric _________________ 1982 924
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast! |
Posted: Fri Feb 13, 2009 2:19 pm Post subject: |
| Cheaper to buy a used engine to replace it. |
Brockoli
Posted: Fri Feb 13, 2009 2:21 pm Post subject: |
+1 to what gohim said,
Thats what i did, i got a parts car for $300 it had a complete non running engine, you can probably find better for the same price where you live. _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
StienbargerR
Posted: Fri Feb 13, 2009 2:59 pm Post subject: |
I think you should look at the crank before you make any decisions. IIRC, I was able to just polish the crank and use standard mains. I got them about 6 months ago. Brockoli, when did you check last? I got mine from EBS
It is a nice feeling to have a freshly rebuilt engine. Mine is running strong. Alot less to worry about in my opinion. _________________ 1978 924 NA
Brockoli
Posted: Fri Feb 13, 2009 3:29 pm Post subject: |
StienbargerR - i havent checked in a while, however, word on the board is that they are no longer available. Ideola is going through a lot of work to get a custom order made right now.
http://www.924board.org/viewtopic.php?t=27377&highlight=main+bearings
i just checked ebs website, they dont have them listed anymore... _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
Posted: Fri Feb 13, 2009 11:00 pm Post subject: |
I'll bet that the crank is so trashed it'll need turning... BTDT. Can't guarantee, but suspect...
I'm with gohim; if anything, get a good used one, put in new rod bearings, rings, and do a valve job, clean parts and all new gaskets/seals, you'll basically have a new engine. _________________ Vaughan Scott
PORSCHEV
Posted: Fri Feb 13, 2009 11:58 pm Post subject: |
I have a rebuild I would sell, but I am sure the shipping would kill that idea in a hurry!
It has 9.3:1 pistons, piper cam, new bearings, valves were reground and new seals. All sealed up with fresh gaskets and seals all around.
Best part is you could brag how the engine was raced all over the world. Well parts were raced in NZ and Canada!  _________________ 1976 924
1978-#53 "D" track racer. |
Boostsideways
Joined: 11 Feb 2009 Posts: 100 Location: CT, Southbury
Posted: Sat Feb 14, 2009 1:53 am Post subject: |
I would also say suck it up and place out that engine with a 944 upgrade or something well yer at it.. But that'll cost you.. Then agian what dosn't tho ? _________________ Just wait 'till my turbo starts firin' the RPM LZR!
My car= Porsche 924 turbo, 1982. |
Posted: Sat Feb 14, 2009 4:25 am Post subject: |
Nobody can give you an accurate, honest diagnosis and estimate of repair costs over the phone on an engine that has been run without oil, unless they are planning on replacing it. There is no way that they could plan without breaking down the engine to see what's inside.
From a financial standpoint, your car is not economically repairable if you are planning on rebuild the engine because the cost of the labor to do the job, or the cost of replacement engine parts will exceed the value of the car each by themselves.
Unless you have thousand of $$$ to burn are are emotionally attached to that particular car, and cannot part with it, buy another car, or a used engine and install it yourself. |
moped
Posted: Sat Feb 14, 2009 7:13 am Post subject: |
To everyone - thanks for all your replies.
I'm on a college student's budget, so I'm looking at whatever is more affordable. I'm from Wisconsin, but am currently in Atlanta with a broken car. My mechanic in WI says he can rebuild it for ~$1500, and can get it towed back to WI for $300. So then, I'm trying to find repairs for under $2000 around Atlanta.
I've been calling shops around town, but more and more, it seems like it's gonna be cheaper to get it back to WI for the repairs.
As for the engine - any suggestion where I could find a replacement? Or another type that would fit in the car for a similar price. |
Posted: Sat Feb 14, 2009 7:43 am Post subject: |
Used the JaXeD parts mash and search Craigslist for donor cars:
http://www.jaxed.com/cgi-bin/sd.cgi
With some persistence and luck, you might be able to find an entire donor car from which to swap the engine (and potentially lots of other stuff) for $300 or so. You just have to be patient and persistent. _________________ erstwhile owner of just about every 924 variant ever made |
StienbargerR
Posted: Sat Feb 14, 2009 9:23 am Post subject: |
I've got some US spec pistons if you need them. Also, make sure to call out to EBS, they are really good to work with and can help you get the parts you may need.
Ryan _________________ 1978 924 NA
Posted: Sat Feb 14, 2009 12:26 pm Post subject: |
For $2000 you should be able to buy a VW MKIII Golf or Jetta as a beater, AND a decent running 924. You can also sell your car for parts.
Unless your dead car is in nice original condition, it isn't worth fixing if you have to tow it and pay someone to fix it for you. |
