The time of year for spring cleaning is coming
pockygt
PostPosted: Fri Feb 13, 2009 2:32 pm    Post subject: The time of year for spring cleaning is coming Reply with quote
And I'm curious as to a few of the routine maintenance things on our cars.
I want to change all the fluids, but I'm a little worried about what problems could be caused by changing fluids that (for all I know) have never been touched. In particular, I'm worried about what'll happen if I change the trans fluid.
Basically, is there any fluid that if changed (when it had not been religiously changed by previous owners) that will do more harm than good?
I know it's a weird question, but I used to have a Ford Probe, and there WAS a problem with changing never-before-touched fluids
1981 924 Turbo (931)
PostPosted: Sat Feb 14, 2009 2:57 am    Post subject: Reply with quote
Just remember to loosen the transmission fill plug before removing the drain plug.
Never heard of tranny problems caused by new clean oil. +You'll probably notice it's quieter after changing.
You're way more likely to have problems due to not changing it.
Change all them nasty old fluids.
PostPosted: Sat Feb 14, 2009 3:02 am    Post subject: Reply with quote
Brake fluid is also a wonderful thing to change out with fresh. Only concern there might be snapping off bleeder screws, but on the plus side, Porsche does a better job of coating bolts etc than Ford, so they're less likely to break off outright...
pockygt
PostPosted: Sat Feb 14, 2009 12:14 pm    Post subject: Reply with quote
yeah, that's what i figured. I didn't want it to be like running a car with natural oil for 200k and then swapping to synthetic and blowing out the seals.
Hah. Nevermind, it was (of course) in the FAQ
PostPosted: Sat Feb 14, 2009 3:43 pm    Post subject: Reply with quote
IMHO, the trany fluid change pertains to a manual tranny. Automatics, you might not want to change the fluid so much
