door window removal
dash16
PostPosted: Thu Jan 08, 2009 10:47 am    Post subject: door window removal Reply with quote
I would like to remove the door window. Can someone please explain how to do this?
Thank you
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
PostPosted: Thu Jan 08, 2009 2:11 pm    Post subject: Reply with quote
Get a big hammer, step back and take a swing.
Oh. Wait. You want to reuse the window?
You have to remove the interior panel, roll the window all the way down, detach it from the bottom brackets that hold it onto the regulator, jimmy the top part out of the grooves, and then lift it up and out. Carefully. There's probably a better how-to around here somewhere if you search, but that's the gist of it.
PostPosted: Thu Jan 08, 2009 5:34 pm    Post subject: Reply with quote
You don't have to disturb the motor?
dash16
PostPosted: Fri Jan 09, 2009 6:51 am    Post subject: Reply with quote
do any of the window seals have to be removed during this process?
STUTTGART PREVAILS
