clutch choice for v8 swap
mcadam1121
PostPosted: Wed Dec 17, 2008 2:21 pm    Post subject: clutch choice for v8 swap Reply with quote
this is for the people that have done a v8 swap and run the transaxle
what did you do for clutch discs
that is really the on part that would be hard if you wanted to use the stock torque tube
did u find a clutch disc the rite size or did you have to have one made
The Ginger
77 porsche 924 Martini
PostPosted: Thu Dec 18, 2008 12:26 am    Post subject: Reply with quote
You should contact Porschev via PM. Also, here's some RECOMMENDED READING where Porschev and MacBDog discuss related issues for Mac's recent V8 conversion.
v8carreragts
PostPosted: Thu Dec 18, 2008 6:28 am    Post subject: Reply with quote
If you have a 924 turbo/944 all you need is a Chrysler disc. Any one with a 1" x 23 spline. They make them up to 12"
If you have a 924 N/A (early) you are stuck with a 9 1/4" Ford disc. (13/16 x 24 spline)
mcadam1121
PostPosted: Thu Dec 18, 2008 10:14 am    Post subject: Reply with quote
What years on the cryslers and fords also what vehicles
The Ginger
alexvex
PostPosted: Thu Dec 18, 2008 11:10 am    Post subject: Reply with quote
I believe the ford is a bronco clutch..do a search, it's been covered.
--Alex--
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951
mcadam1121
PostPosted: Sat Dec 20, 2008 4:03 pm    Post subject: Reply with quote
Well I looked it up and I believe a Chevy v8 uses a 11 3/8 disc if u use the 944 tranny with the 1"shaft.& 23 splines a disc out of a 85 dodge 1/2 ton will fit perfectly
The Ginger
