Windows died.
Frank.Ind
PostPosted: Wed Oct 22, 2008 9:48 am    Post subject: Windows died. Reply with quote
My electric windows died a few days ago (both sides).
As I understand it, this is a result of either the fuse or the relay.
Question is which is the fuse/relay for the windows (UK model if that makes any difference?)
Thanks for any help given.
ditch68
PostPosted: Sun Oct 26, 2008 7:17 am    Post subject: Reply with quote
Here is a link to the Tech section of this site which has a fuse/relay map. Acording to the list on the page, (electrics>relay and fuse ID/locations), it is position 8 on the addiional fuse panel.
http://www.924.org/techsection/technical.htm
Hey, I answered a question instead of asking one!
Also check the contacts on the switches.
Jeff
Current:
1979 924, all stock.
1988 951 all track modded out and angry.
Past: 1986 951, 1988 924S, 1965 912 with '69 911T engine.
bcblase
PostPosted: Tue Oct 28, 2008 9:53 am    Post subject: Reply with quote
Any solution on this yet? I have the same problem - both windows died.
Switches are OK, fuses are OK, motors are OK, no relay listed for windows...
Still looking for a solution...
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
PostPosted: Tue Oct 28, 2008 2:09 pm    Post subject: Reply with quote
Have you considered a Mac?
Frank.Ind
PostPosted: Wed Oct 29, 2008 6:57 am    Post subject: Reply with quote
Unfortunately still no solution.
I have no idea were this magical window relay lives!
I did have fun on Sunday when the windows started working again only to pack up (open) as the rain came. Had to cobble a "jumper" to get the drivers window closed.
Also "8" on my Aux fuse panel is lacking a fuse or any cables going to it.
It looks like theres never been one...
Looks like Im spending this weekend tracing wires.
Frank.Ind
PostPosted: Sun Nov 09, 2008 8:17 am    Post subject: Reply with quote
Well they're still dead
Cant trace the wires without pulling the carpets out by the looks of it.
Hope someones got an idea...
PostPosted: Sun Nov 16, 2008 4:22 am    Post subject: Reply with quote
Power window relay - On my car (late '82, so it has the same HVAC system as yours), the relay is clipped to the side of the HVAC box - easily accessible from the left footwell (your passenger side)(check the other side if it's not there). You may find a "radio" relay clipped on right next to it.
Frank.Ind
PostPosted: Sat Apr 25, 2009 9:31 pm    Post subject: Reply with quote
FINALLY A SOLUTION!
If anyone else has problems with both windows not working, the window relay part number is:
944 615 112 00 30gbp direct from Porsche!
Located (On RHD cars) to the right of the fuse box next to the center consol.
Its red BTW.
I hope this helps some one else.
joecitizennn
PostPosted: Wed May 13, 2009 2:02 pm    Post subject: Reply with quote
fukin Bill Gates.
PostPosted: Thu May 14, 2009 12:41 am    Post subject: Reply with quote
Get Bill Gates in heyuh!
masterdave
PostPosted: Tue Jun 23, 2009 4:38 pm    Post subject: motors Reply with quote
could be the window motors them selves, strange they could both blow at the same time, possible the result of a surge that the fuse did not protect. there are a couple of blank spots on the fuse box, porsche and VW liked to make interchangeable parts so there are always blanks and lose wires as a result of systems being combined. check the switches but sounds like if the fuse is ok and the wires are ok its the motors.
88Silver924S
PostPosted: Wed Aug 12, 2009 1:14 pm    Post subject: Learn to take apart switches and clean Reply with quote
For what it is worth I have had my 88 924s since new and every several years I have to take apart one of the window switches and clean the internal contacts (rather than buy a new switch for $40). It is not hard but besure to get it back together the same as it was.
