M030 or OEM equivalent
dash16
PostPosted: Thu Oct 09, 2008 6:30 pm    Post subject: M030 or OEM equivalent Reply with quote
Let's face it, my 924s handles spongy, sqeeks in the rear, and it clunks when it runs over the smallest stuff.
With that said, I really want to replace the suspension components. Since I have to get dirty in there, why not go M030?
My problem is that I don't know where I can get my hands on a fresh set of M030 components(maybe other than selling a kidney at the dealership).
Where can I find *fresh* M030 parts or the OEM equivalent of these parts? And hopefully all from one vendor.
I am talking struts, springs, torsion bars, sways, and bushings etc.
Thank you.
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
PostPosted: Thu Oct 09, 2008 10:23 pm    Post subject: Reply with quote
I don't know if these guys have *everything*, but one of these two will have most of what you're after:
http://www.paragon-products.com
http://www.elephantracing.com/suspension/packages/944packages.htm
Here's some other resources that might help
http://www.ground-control-store.com
http://www.racersedge-inc.com/index.html
bcblase
PostPosted: Fri Oct 10, 2008 12:04 am    Post subject: Reply with quote
The Paragon Products "suspension packages" are a pretty good deal. They are mainly for 944Cup/944Spec racers, but all the stuff you need should be there.
The "Spec 4" Package is for the 924S.
http://www.paragon-products.com/product_p/944spec-4.htm
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
dash16
PostPosted: Fri Oct 10, 2008 1:54 pm    Post subject: Reply with quote
BC
it looks like the only OEM equivalent in this package are the koni struts.
the sway diameters seem to be different, and the choice of torsion bar size and spring rates make this package all the more confusing.
I do appreciate the lookup though!
STUTTGART PREVAILS
ditch68
PostPosted: Sat Oct 18, 2008 2:46 pm    Post subject: Reply with quote
Thanks for posting these links. I was hoping to find a reasonably priced package just like Paragon's. Definitely on my wish list.
I can't seem to get the 924S "Katalog" to load (.pdf file). Anyone have it saved on their harddrive?
Jeff
Current:
1979 924, all stock.
1988 951 all track modded out and angry.
Past: 1986 951, 1988 924S, 1965 912 with '69 911T engine.
dash16
PostPosted: Sat Nov 08, 2008 10:02 am    Post subject: Reply with quote
try right-clicking and saving instead of just loading it into your browser
STUTTGART PREVAILS
PostPosted: Sat Nov 08, 2008 10:29 am    Post subject: Reply with quote
You sure you want to reindex your t-bars?
It sounds to me like your suspension is just worn out. You might want to start out with something less labor intensive and see how you like it.
Example:
  • Refresh control arm bushes (Prothane brand, look for "Golf/Rabbit Mark I," do NOT get Weltmeister) - $25
  • Bilstein shocks and struts (Allshocks.com) - $400
  • Lindsey 19mm rear sway (lindseyracing.com) - $150
  • the largest front sway you can find from Ebay or a junkyard (partsheaven.com) -$75
I guarantee the car will handle awesome and TOTALLY unlike it does now, and you may be satisfied to stop there. It really is a bitch to get into t-bars, and you might not like the ride of the Spec suspension.
PostPosted: Sat Nov 08, 2008 11:59 am    Post subject: Reply with quote
I have a couple of spare 23mm front sways floating around, one of each variety (solid early 924 style; tubular 944 style)...
PostPosted: Sat Nov 08, 2008 2:27 pm    Post subject: Reply with quote
Try HEYUH.
NBRettie18
PostPosted: Sat Nov 22, 2008 8:20 pm    Post subject: Reply with quote
Example:
Why don't get Weltmeister control arm bushings? i have them on the rear of front, along with a 30 mm in the front and 19 in the back.
1987 924S - MO30 30/19 - Yellows all around
PostPosted: Sun Nov 23, 2008 3:26 am    Post subject: Reply with quote
Poor quality. . .keep an eye on them and you will see what I mean after you have run them for a while.
NBRettie18
PostPosted: Mon Dec 01, 2008 5:00 am    Post subject: Reply with quote
huh, thanks for the tip, i will keep an eye on them
