Petrovich
Joined: 27 Sep 2005 Posts: 235 Location: Rockville, MD
Posted: Fri Oct 31, 2008 1:08 pm Post subject: Wastegate to cat pipe - how does it seal? |
Was checking my exhaust leak tonight (my temporary home-made J-pipe gasket finally blew, ordered the real thing). Found another leak, which kinda explained the excessive exhaust noise and loud-ass rattling at mid-to-high RPM's. My wastegate-to-cat pipe has a banged-up metal doughunt hanging on it, and the pipe goes into the flared pipe stub on the cat itself. I ordered an o-ring for that one as well, but I have NO CLUE about the part that's supposed to be holding it on (as in, there's nothing pressing the current seal into the flare on the cat). In other words, if it ever existed, I ain't got it.
Does anyone know what's supposed to be there, and where I can get this... whatever it is? _________________ 1982 924 Turbo, now Lemon |
Posted: Fri Oct 31, 2008 1:13 pm Post subject: |
Ever seen the clamps holding a VW Beetle (old) muffler to the heat exchangers coming off the back cylinders? Same thing!
PCNA has this. Got PET? _________________ Toofah King Bad
Petrovich
Posted: Fri Oct 31, 2008 1:41 pm Post subject: |
20$ plus nuts and bolts... Or 15$ for the beetle one Is beetle part the same? I'll be at the junkyard this Saturday, i'd be really happy if I grab one there Or should I stop dreaming and get the new OEM clamp? _________________ 1982 924 Turbo, now Lemon |
Posted: Sat Nov 01, 2008 12:54 am Post subject: |
| Petrovich wrote: | | Or should I stop dreaming and get the new OEM clamp? |
Cough it up, man. These clamps decay. . .a used one is not going to be helpful. _________________ Toofah King Bad
Petrovich
Posted: Sat Nov 01, 2008 1:40 am Post subject: |
Ok, looked some more...
In addition to the actual gasket (which was $13 by itself plus shipping, $21 total), it needs a crush ring (the rattly thingie that I still have, it seems) and both clamps from a 76 911 (I was looking at the wrong part last night). $13 crush ring, $16 for EACH HALF of the clamp, plus fateners and more shipping. All in all, 60$
If I could afford to spend 911 money on a superficial exhaust leak, I'd drive a 911, wouldn't I
Am I even looking at the right parts?
PET doesn't show the right picture - their wastegate attaches to the pipe directly and then goes into the cat, mine goes alongside the cat and enters it in the middle. Theirs doesn't even have my joint. I just crawled the board to get the part number for the o-ring, and deduced that since it was a 911 part, the rest of the hardware was from the same 911 joint as well.
I'd get beetle clamps new if I knew they'd work - are they all the same diameter, or is there a difference? I'm not getting the gaskets till next friday - I think I'll go ahead and pull some junkyard clamps just to see if they'll work, then get new ones for a veedub. _________________ 1982 924 Turbo, now Lemon |
Posted: Sat Nov 01, 2008 2:00 am Post subject: |
Parts list:
Support washer - 930 123 132 02
Gasket - 930 123 134 04
Clamp halves (2 needed) - 930 123 133 00
You're right, it's $60+ at Sunset not including bolts!
You might measure the OD of the wastegate pipe, and then run over to your VW parts house and measure the ID of the Beetle part. . .it is definately the same setup. See HERE for reference. _________________ Toofah King Bad
Petrovich
Posted: Sat Nov 01, 2008 3:40 am Post subject: |
I don't know any VW suppliers around here... This is the wrong Washington I'm living in - I haven't seen a classic Beetle in ages
I know Mt Airy yard had some Beetles and a 914, I'll see if they still have any exhaust parts left that might look like that. I'll report tomorrow if it's a match or not. _________________ 1982 924 Turbo, now Lemon |
Petrovich
Posted: Mon Nov 03, 2008 3:12 pm Post subject: |
Ok, got to try the Beetle clamp that I pulled at the junkyard yesterday. It *sorta* fits, but it appears as if the pipe diameter is one size larger. Not by much, but a little bit. I'll have to wait for the gasket to see if the clamp is conforming enough - if not, I'm stuck with a 70$ order and another week of waiting
Those things do, indeed, rot. The clamp set I took was the best one on the whole yard, and even then I managed to break one of the bolts. Another one on a different Beetle just fell apart in my hand.
I did get to see the strangest Fiat... with a tiny little engine stuck in the arse longitudinally - and it was a convertible. Looked like a miniature Spider with an engine on the wrong end. Didn't look all that bad, either. _________________ 1982 924 Turbo, now Lemon |
Posted: Tue Nov 04, 2008 1:23 am Post subject: |
| Petrovich wrote: | | I did get to see the strangest Fiat... with a tiny little engine stuck in the arse longitudinally - and it was a convertible. Looked like a miniature Spider with an engine on the wrong end. Didn't look all that bad, either. |
Fiat X1/9?
Great little car! My first car was a 1974, originally painted lime green, but resprayed to candy apple red. It was instant deja vu when I first experienced the 924 NA...very similar handling and balance. Of course, the 924 has been MUCH more reliable! _________________ erstwhile owner of just about every 924 variant ever made |
Petrovich
Posted: Tue Nov 04, 2008 2:43 am Post subject: |
Nonono, better - I matched it to a picture of an 850 Spider:
Apparently, those have an engine that would barely shame a small motorcycle - 800cc. The motor looked like a little toy, for sure - MG Midget's engine is a giant by comparison.
I wonder what one could squeeze out of that motor, boosted and fuel-injected  _________________ 1982 924 Turbo, now Lemon |
Posted: Tue Nov 04, 2008 10:23 am Post subject: |
Engines for the 1965-1974 Fiat 850 Coupe & Spyder:
Type Size Horsepower Years
ohv I-4 843 cc (51 cid) 54 hp 1965-1968
ohv I-4 903 cc (55 cid) 60 hp 1969-1974
Notice that it has more than 1 hp per cid. _________________ White 87 924S "Ghost"
Petrovich
Posted: Tue Nov 04, 2008 10:47 am Post subject: |
Holy krapp
It probably walks all over the MG's of that vintage - more power in a smaller, rear-engined car. From the looks of it, rusts slower, too  _________________ 1982 924 Turbo, now Lemon |
