911 clutch kit combo for 931?
PostPosted: Sat Nov 01, 2008 2:47 am    Post subject: 911 clutch kit combo for 931? Reply with quote
Is this the clutch kit from a 911 that works with the 931? Dave
http://minneapolis.craigslist.org/pts/900543599.html
924guy
PostPosted: Sat Nov 01, 2008 11:41 pm    Post subject: Reply with quote
get part numbers from seller before doing anything...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
gegge
PostPosted: Mon Nov 03, 2008 9:08 pm    Post subject: Reply with quote
Please note that the throw-out bearing and clutch disc from 911 canīt be used on 931. The preasure plate from 911 72-86 is the one, but there are different:
* All iron, like original 931 (Heavy!)
* Alloy housing, iron friction plate
* All alloy. (Very light and expensive!)
Carl Fredrik Torkildsen
PostPosted: Mon Nov 03, 2008 11:05 pm    Post subject: Reply with quote
Check!
THe dude got back to me with the part number 915 116 001 27. Appears to be the correct number. Is it worth 299 bucks if only the pressure plate is used out of the kit? dave
PostPosted: Tue Nov 04, 2008 1:09 am    Post subject: Reply with quote
No. You can get the correct pressure plate from this eBay seller for $199.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=260300638578
To add to what gegge posted, the all-alloy version requires modification to use in a 931, at least according to some posts floating around here by -nick and bass gt (I think this is the thread). The pressure plate to get is the middle one, the alloy+iron version. This version is a direct bolt up, but make sure you remove the ring gear from your old pressure plate.
And FYI, it provides double the clamping power of the stock unit, which is good for higher output situations. I don't know what this does to the pedal feel, and I don't know if this applicable to hydraulic clutch setups, but you may want to consider reinforcing the firewall where the clutch cylinder mounts up. I recently discovered two cracks in the firewall sheet metal around that opening on my UWB project, which was running just a stock setup. The only way to see the cracks is to remove the brake booster and all of the thick plastic heat shielding. Now would be the time to check it out.
PostPosted: Tue Nov 04, 2008 11:06 am    Post subject: Reply with quote
Thanks for the info.
