Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Mon Oct 27, 2008 4:21 am Post subject: Vertical play on rear wheels |
I have got vertical play on the rears wheels.
I usume if it where worn bearings I would have horizontal play as well ?
What could it be ? _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
Joined: 29 Jul 2001 Posts: 9132 Location: Royal Oak, MI, USA
Posted: Mon Oct 27, 2008 8:05 am Post subject: |
Yes, you would... so perhaps a suspension alignment bolt has come loose, or a shock mounting, or something like that?
I use a paint pen to mark all the bolts on my suspension, so it's easy to see if they've come loose... _________________ Vaughan Scott
Posted: Mon Oct 27, 2008 1:43 pm Post subject: |
Safety wire is usually a better solution for that but using the paint marks isn't a bad idea as well. _________________ Stefan
Rich H
Posted: Mon Oct 27, 2008 8:08 pm Post subject: |
Cehck see what is movign, if its just the stub then its bearings, if its the control arm its a loose bolt if its the spring plate you have torsion bar issues. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Mon Oct 27, 2008 9:18 pm Post subject: |
| Rich H wrote: | | Cehck see what is movign, |
You took the red pill again didnt you? _________________ Porsche 924 1984 (UK import) NA
Posted: Mon Oct 27, 2008 10:08 pm Post subject: |
Safety wire or loctite (we use both, depending on application) are to keep things from moving. Paint allows us to perform a quick visual check on every bolt in sight when a wheel is off, without having to even grab a single wrench. _________________ Vaughan Scott
Rich H
Posted: Mon Oct 27, 2008 10:23 pm Post subject: |
| Ozzie wrote: | | Rich H wrote: | | Cehck see what is movign, |
You took the red pill again didnt you? |
Nope, I think that is the problem.  _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Tue Oct 28, 2008 4:54 am Post subject: |
Yeah, nutting and bolting a race car (especially a door slammer) is a pretty boring job. _________________ Stefan
Martijnus
Posted: Tue Oct 28, 2008 10:43 am Post subject: |
| Rich H wrote: | | Ozzie wrote: | | Rich H wrote: | | Cehck see what is movign, |
Nope, I think that is the problem.  |
so what would happen if you took both pills...would you get in some kind of limbo? _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Rich H
Posted: Tue Oct 28, 2008 6:16 pm Post subject: |
I buy another car...  _________________ 1994 Lotus Esprit S4 - Work in progress...
