EEC System question (lots of pics)
Goto page Previous  1, 2
John Brown
PostPosted: Sun Oct 26, 2008 11:15 am    Post subject: Reply with quote
Not up on every possible variation here; especially very early cars that had air pumps and egr. However:
Some one, somewhere, some time, seriously messed with the motor.
The charcoal canister never vented into the crankcase that I know. Anybody? It should vent to the intake. IIRC should go the rear of the air filter box. Or the connection between the metering unit and the intake.
Extremely skeptical about that fitting on the case vent on the side of the block. The oem hose that fits on there looks to be very large but there is a restrictor inside and the actual vent hole is about 1/8" IIRC. (Which might account for a large quantity of oil getting tossed up. Although there is a screen inside the fitting). Have you found anything in the parts book that looks like that fitting? I mean, at that location?
Even with 5000 mile since you loosened it up; unless you took serious measures to 'clean' the motor after sitting for such a long time there still could be 'gunk' in the rings and etc.
BTW, the turbo and several 924DP motors I've seen did have a vent placed at the flat where the original fuel pump bolted. You should not need that vent; but if you wanted to try it as an interim fix that location would be in keeping with previous usage.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
Brockoli
PostPosted: Mon Oct 27, 2008 7:30 am    Post subject: Reply with quote
john brown - the motor was from my '77 parts car. It has been rebuilt. What they did tho is a mystery. It has a head from a '81. The person that rebuilt it may of only done head work. I dont really know.
The charcol canister does not vent to the crankcase. I was mistaken. The fumes from the charcol canister mix with fumes from the crankcase and go to the air box like you said.
The picture of the crankcase vent with the questionable fitting was on my other engine that is not in the car. I took a pic of it because it was easier to access. The engine in my car has a different fitting, that is less questionable. But i dont remember what size of hose goes to the airbox, maybe that one is oversized too.
What measures should I take to clean out the rings. Are there any ways of doin this without taking the engine out.
I dont understand what you are talking about with respect to the turbo and 924DP motors? What vent are you talking about by the original fuel pump?
thanks for your help
Chrenan
PostPosted: Mon Oct 27, 2008 8:39 am    Post subject: Reply with quote
You can sort of see it in the picture below.
Just to the right of the oil filler cap (mesh) you will see a hose running into the head. It runs into the head right where the block-off plate is on our cars. The plate blocks the hole where a mechanical fuel pump can be driven off the cam.
Chrenan
PostPosted: Mon Oct 27, 2008 9:30 am    Post subject: Reply with quote
Brock, take this advice with a grain of salt as it is a technique me and a friend used to use on dirt bikes when we were kids after running in really dusty areas. Gas down the spark plug hole directly into the cylinder. You'd need to drain the oil first, and leave the drain plug off the pan and just let the gas seep through the rings on each piston and out the drain. Then hit the cylinders with some fogging oil and turn the engine over by hand to re-lube the cylinder walls. I'm not sure if this is really an appropriate technique on the 924, so you may want to wait until a less "hack" mechanic weighs in with some real advice.
PostPosted: Mon Oct 27, 2008 9:53 am    Post subject: Reply with quote
Chrenan wrote:
A bit off topic, but Chrenan, you wouldn't happen to have any more photos of that D-prod car there would ya? If so, could you send 'em my way?
Chrenan
PostPosted: Mon Oct 27, 2008 9:57 am    Post subject: Reply with quote
Sorry, that's the only one, I scanned it from 911 & Porsche World as an example of a strut brace, there actually weren't anymore engine bay pics from the article that I remember.
Brockoli
PostPosted: Tue Oct 28, 2008 5:09 am    Post subject: Reply with quote
chrenan - thanks for clarifying. I had no idea about that. Cool pic!!! I might try the gasoline thing, im goin to google howto clean out rings maybe some good stuff will come up. Ill run that idea by my mechanic friends see what they say...
Chrenan
PostPosted: Tue Oct 28, 2008 5:31 am    Post subject: Reply with quote
Remember my catch-all tip when working with gasoline, smoke menthol cigarettes as it will cut the gross fuel smell.
Brockoli
PostPosted: Tue Oct 28, 2008 5:44 am    Post subject: Reply with quote
you also told me to look into the fuel sending unit with a lighter to see if there was rust in there. My eyebrows are just growing back
Page 2 of 2
