Nine24
Joined: 16 Jul 2008 Posts: 26 Location: Manchester, England
Posted: Mon Oct 20, 2008 12:55 am Post subject: Alternator? |
Hi' Guys
Does any body know if the 2000cc turbo alternator fits the n/a 2000cc???
I ask this because my current alternator has had the brushes replaced and a new voltage regulator, it was fine for a short while but is charging poorly again?? my alternator doesn't seem to have the cooling duct going to it, could this be the cause of poor charging? _________________ Black 1984
924 1984cc N/A |
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Mon Oct 20, 2008 2:12 am Post subject: |
Are you sure it is not a grounding problem?
Did you have an alternator shop test your alternator?
I had mine tested, it took just a couple of minutes and was free of charge.
If the copper rings the bushes run on are damaged, the alternator will eat through the bushes in no time.
And yes you should install the back cover and cooling hose.
Duncan |
Nine24
Posted: Mon Oct 20, 2008 2:36 am Post subject: |
Yeh just checked the ground strap, it seemed ok but need to take it off the car really. I had a mechanic replace the brushes and regulator about 3 months ago, he said it'll be fine after that but its slowly started to charge poorly to the point where all my gages are going out of whack and the car becomes difficult to start after a hot run. Theirs a turbo alternator on ebay for cheap that I'm thinking I mite buy? _________________ Black 1984
924 1984cc N/A |
Duncan
Posted: Mon Oct 20, 2008 2:51 am Post subject: |
Well I don't know.
I got an exchange (like new) laternator for 100 euro ex vat = 80 pounds ex vat.
You can also buy another voltage regulator and see if this helps, reasoning that the old one died so quickly in such a hot environment.
A Hella voltage reg costs something like 10 euros. It is just screwed to the back of the alt. If you have the alt out, it takes one minute to replace the voltage reg.
But, like I said before. Only having the alt tested will decide if your setup is at fault or the alt...
Duncan |
Nine24
Posted: Mon Oct 20, 2008 2:58 am Post subject: |
Yeh, thanks Duncan i think i'll take it back to the mechanic and ask him to preform some tests. _________________ Black 1984
924 1984cc N/A |
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Mon Oct 20, 2008 6:47 pm Post subject: |
Last time I changed mine I got a fully recon'd unit from GSF car parts http://www.gsfcarparts.com/ £75 + vat. _________________ Mars Red '78 Euro 924 n/a
There are two kinds of pedestrians: the quick and the dead. |
Slam
Joined: 07 Jan 2005 Posts: 1689 Location: Wainwright, Alberta, Canada
Posted: Tue Oct 21, 2008 2:26 am Post subject: |
To answer your first question, yes, it'll bolt right in. That said, considering new ones are fairly cheap, maybe that's the way to go (says the guy who disassembles his to change the bearings...). _________________ '84 944 - kid blew motor
'83 944 - resting comfortably. For 12 years
'87 944 - sideswiped by trucker
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably |
