Electric Porsche - Sports EV.....
paulh
PostPosted: Fri Oct 10, 2008 2:46 pm    Post subject: Electric Porsche - Sports EV..... Reply with quote
Hi My 924 NA 1981 refuses to start, it was overheating when I last ran her, and I'm not sure what to expect. There was also a kind of "ticking" noise under hard acceleration.
heads?
valves?
any ideas ?
Mont Macedon Victoria Australia
1981 942 NA was brown now red- soon to be an Electric Porsche
Scorpio
PostPosted: Fri Oct 10, 2008 5:09 pm    Post subject: Reply with quote
Paul..throw your question over to general discussions
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
paulh
PostPosted: Fri Oct 10, 2008 7:57 pm    Post subject: Reply with quote
I thought I had,
thanks though
PostPosted: Fri Oct 10, 2008 11:38 pm    Post subject: Reply with quote
Is the fuel pump running and are you getting fuel at the injectors?
Are you getting spark?
If yes to both then it could be timing belt has slipped and ign and valve timing is up the creek.
A compression test will tell if the head, rings or valves are shot
paulh
PostPosted: Sat Oct 11, 2008 5:23 am    Post subject: Reply with quote
yep, got fuel got spark.
Timing belt slipping sounds good, that should also produce a lack of compressions to won't it/
PostPosted: Sat Oct 11, 2008 7:27 am    Post subject: Reply with quote
If the belt has slipped then the valves can be open when they are meant to be closed and cause lack of compression, backfiring and no start.
paulh
PostPosted: Sat Oct 11, 2008 4:35 pm    Post subject: Running on two cylinders.....!#@$!@ Reply with quote
Ok, I've done a real work over and go it started, checked the belt timing Ok.
Only front 2 cylinders running, as in the car will start with plug leads to back 2 cylinders un-plugged and not make a real difference when plugged in.
Runs rough and has a lot a "clatter" in the sound
injectors Ok.. tested by un plugging and spraying into a jar, swapping them doesn't really change things.
So why running on 2 cylinders?
burnt valves?
tappet adjustment right out?
Another strange thing is a "grinding" sound that seems to come from the "fuel distributor" don't really know what it is....
Thanks for help so far .
PostPosted: Sat Oct 11, 2008 8:17 pm    Post subject: Reply with quote
leads are stuffed?
Martijnus
PostPosted: Sat Oct 11, 2008 9:06 pm    Post subject: Reply with quote
I'd go for a compression test.
Overheating can be killer
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Sun Oct 12, 2008 7:39 am    Post subject: Reply with quote
I think I mentioned compression check.
Tool is cheap and determines real quick if the motor is fubar.
968rz
PostPosted: Sun Oct 12, 2008 10:56 am    Post subject: Reply with quote
+1 on the comp test, also verify that the HG didn't bolw. Look for milk shake in the oil, if you can get a cooling system pressure tester; pump it up to about 12lbs and leave it sit till morning then check for coolant in the cylinders.
Rick
93 968 coupe Amazon Green 4spd Tip (my DD)
paulh
PostPosted: Sun Oct 12, 2008 11:45 am    Post subject: Reply with quote
Thanks Guys... am picking up compression tester tomorrow.
will let you know.
paulh
PostPosted: Fri Oct 17, 2008 1:40 pm    Post subject: Confirmed head gasket ....or worse Reply with quote
yes, I can confirm that I have lost the fight and the headgasket is gone, starting it pushed the water into the oil eeeeeeek
any handy hints to replacement?
thanks for you help thus far.
PostPosted: Fri Oct 17, 2008 10:11 pm    Post subject: Reply with quote
Well, good news is it's a relatively simple job.
Consider having the valves done while you have it off; plan to clean everything thoroughly.
paulh
PostPosted: Tue Oct 21, 2008 1:33 pm    Post subject: Electirc Porsche - Sports EV Reply with quote
Convert the Porsche to run on batteries....
I guess it's now a bit more work than the just the head, and a gasket....I'm getting help.
My drive train engineer brother in law has said it's do-able. We are currently preparing to do the job then we will release the detailed plans. Circuit diagrams and any software developed.
I am setting up a website to blog about progress here it is Electric Porsche
At the moment we are wanting to make it really perform as opposed to being a practical daily car.
If any one has any advice for us please let me know. I'm guessing that I'II be in regular contact with lot's of questions. So I'd like to thank in advance anyone who does helps.
electricsports.org Electric Porsche plans
