kris Guest
Posted: Fri Apr 19, 2002 10:15 am Post subject: |
| I am in need of a 1981 or 82 931 Ignition Control Unit (unit behind the radio, under the center console). I need it to get my 1981 931 back on the road. ITS SUMMER TIME!! HELP!!! |
turbobob924 Guest
Posted: Mon May 06, 2002 1:44 am Post subject: |
If it is the main ECU, part 931.617.101.00
I have one.
email me seperately, bward@newtekdata.com |
Smoothie Guest
Posted: Mon May 06, 2002 8:52 am Post subject: |
That little dude behind the radio on '81s and '82s is the Digital Ignition Timing Control or "DIC". Also refered to as "DITC".
Why are you looking for one? Missing? or just suspect it's bad? - because often the only problem with them is a bad connection - the rectangular multiwire connector is known to get flakey and just needs to be unplugged, cleaned and replugged (or just unplugged/replugged)(or just jiggled).
kris Guest
Posted: Tue Jul 23, 2002 3:00 am Post subject: |
Actually the Box was missing all together. I ended up getting one from Bobby Dodd. But now I am having trouble locating 2 of the three cables that plug into it. One being the impuls Sender & the other being the threaded vaccum fitting that mounts on the intake manifold. I think they might be missing. So if anyone has these cables/hoses, let me know because I may need them also.
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Tue Jul 23, 2002 6:49 am Post subject: |
The vacum line is just that and I'll see if I can dig one up. Just two Banjo fittings clamp to a rubber hose.
I think I sold my last sensor a while back, but there is one on ebay I think.
I'll look for one in the meantime
_________________ Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951 |
kris Guest
Posted: Tue Jul 23, 2002 7:14 am Post subject: |
Hey Bobby, how much do you want for the one that you DO have? I looked on ebay & couldnt locate the impulse sender. If you do have one of those too, let me know...
Chris |
