wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Wed Oct 01, 2008 11:00 pm Post subject: Oil problem |
OK I have a problem and I really dont want to know the answer as I suspect that it is not going to be a good one.
I have been getting a small to medium amount of oil coming out of my dipstick so I decided I would check it out a little more as it was beginning to worry me. when I blocked the pipe from the crankcase breather to the airbox I got more oil out the dipstick about a 2cm circle under the car after only about 2 min of ideling, can anyone point me in the right direction to fix this issue, I know what I am thinking and I dont like it much so I am hoping that someone has a better explanation than mine. _________________ 1977 924 2.0 Auto |
Posted: Wed Oct 01, 2008 11:12 pm Post subject: |
Crankcase breather is clogged? _________________ erstwhile owner of just about every 924 variant ever made |
Thruxton900
Joined: 05 May 2008 Posts: 51 Location: Adelaide, South Australia
wombat
Posted: Thu Oct 02, 2008 8:06 pm Post subject: |
Thanks guys, This is what I was thinking also, I was going to clean it out a while ago but getting it out looked like a task and getting it back in didnt look much better, anyone have any tips or advice on how best to achieve this. _________________ 1977 924 2.0 Auto |
leadfoot
Posted: Thu Oct 02, 2008 9:43 pm Post subject: |
flat blade screwdriver to pry the edges around the ufo (breather) work around in a circle against the block.
Then when it pops off make sure you don't drop anything into the hole.!!!
Get a can of engine grease/oil remover and spray away, let soak for a while and rinse off.
carbon fiber GT mish mash
Thruxton900
