faulty indicators (turn signals)
scotthusky89
PostPosted: Fri Aug 15, 2008 3:09 am    Post subject: faulty indicators (turn signals) Reply with quote
can anyone help i have three issues one was the brake lights where'nt working they are fixed reverse lights stay ed on but they are sorted
my last problem is the indicators i turn the indicators on left or right the dash board shows the light come on constant but neither the left or right lights come on all the bulbs work even putting the hazard waring switch on the dashboard light says they are working but the same problem light stays on on dashboard but no lights work
anyhelp cheers
hi everyone nice to see and talk and hear from u
82 924turbo s2 english rhd verson
View user's profile Send private message AIM Address MSN Messenger
dpw928
PostPosted: Fri Aug 15, 2008 6:06 am    Post subject: Reply with quote
It sounds like the same thing that happened to mine when I tried a generic flasher/relay. May want to check all of your fuses, relay and bulb grounds/contacts.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
malpaslane
PostPosted: Thu Sep 04, 2008 5:19 pm    Post subject: Reply with quote
Hi, don,t know if you,ve sorted this one ,but it sounds like the relay, if you need one i,ve got loads , Rik....
931 1982, PAIN IN THE ARSE,BUT GETTING THERE. 911 1976 2.7. 931 1981 S2(NON RUNNER) ALFA 156 SPORTSWAGON.
scotthusky89
PostPosted: Thu Sep 25, 2008 8:40 pm    Post subject: Reply with quote
yep found out it to be the relay so need to get a new one but also im looking for reverse switch as well
924turbo_sout_africa
PostPosted: Thu Sep 25, 2008 9:25 pm    Post subject: Reply with quote
the reverse switch take it out and have it matched as far as i know the same as a glof 2...but i got mine from porsche cost was R55 rand so just find out they not that expensive ...o yes 1 dollar = R8.15 rands....
Porsche ...where dreams are a reality
'79 924 turbo canada spec
'98 Formula Vee (M3 eater)
Time in the 931 is a dream come true !!
scotthusky89
PostPosted: Sun Sep 28, 2008 3:49 am    Post subject: Reply with quote
cheers lads turn signals completed found it to be the relay plus a smaall fuse
cheers
