931 oil leak/hose questions
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board
Guest
PostPosted: Thu Mar 02, 2000 2:32 am    Post subject: Reply with quote
Email: nitrusmr2@yahoo.com
Date: 02 Mar 2000
Time: 03:32:10
I have been doing some searching for the oil leak(s) on the front of my 931. The good news is that it is not the engne or front main seal. So far I have found 3-4 sources. Bot oil cooler lines are leaking at the point where it changes from hardlines to flexible lines. The other 1 (or 2) leak(s) appear to be coming from 2 braided hoses right under the air filter box. One appears to be the PCV hose and connects to the rubber bellows on the turbo inlet. The other is totally unclear to me. Can I remove the PCV hose that connects to the turbo and just install a breather filter where it used to connect (and cap the hole on the bellows?) What is that other hose for? thanks, Aaron
Guest
PostPosted: Thu Mar 02, 2000 3:28 am    Post subject: Reply with quote
Email:
Date: 02 Mar 2000
Time: 04:28:20
Well it's a poor man's Porsche, just use duct tape or JB weld or something. lol
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board All times are GMT + 10 Hours
