xEcUtEr
Joined: 11 Apr 2008 Posts: 30 Location: Lisbon - Portugal
Posted: Thu Sep 11, 2008 11:05 am Post subject: Roll-Cage |
Hello,
i want to fit a Roll-Cage into my 79' 924, i would like to do it myself for less €€€
Does someone has a sketch of it??
Or where can i get it or an low-cost one?!?
The problem is that i live in Portugal and Shipping it's fatal!
Regards _________________ 79' 924 2.0 @ Estoril Track |
Posted: Thu Sep 11, 2008 11:17 am Post subject: |
Some good pics of one here - http://www.924board.org/viewtopic.php?t=21492 _________________ "..it's made in Germany. You know the Germans always make good stuff."
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Chrenan
Posted: Fri Sep 12, 2008 12:05 am Post subject: |
That is my autopower roll-bar. Excellent for the appropriate use of harnesses and one-piece bucket seats with harness pass throughs.
A roll-cage is a different animal as it has structure ahead of the front seats, including a forward roll hoop, door bars, knee bar. A roll-cage is really for a race car and should be built to the governing body's specification for whatever type of racing you are doing. _________________ 1987 951 - M193 Version for Japan |
Posted: Fri Sep 12, 2008 12:43 am Post subject: |
. . .and a full race cage with bars coming forward of the front seats should only be used with a helmet, otherwise they can bust your melon. _________________ Toofah King Bad
Posted: Fri Sep 12, 2008 7:21 am Post subject: |
Don't forget that if you do take the car to a track, they they'll likely want to make sure the bar is built and installed to their specs. This includes the seat (which usually needs a collapsible support brace from the seat back to the main roll hoop) the Harnesses (proper angles to prevent spinal compression, proper mounting hardware) So be sure to do your research before plopping a bar into place.
Finally, a bar designed for a 944 will work as they are the same basic chassis, so that might help widen your search. More than likely you would have to have it shipped from Germany or England, unless you can take some time and pick it up while on Holiday. _________________ Stefan
xEcUtEr
Posted: Fri Sep 12, 2008 11:10 am Post subject: |
That's exactly what i'm looking for...
in Track Days we don't have much specs to respect... it isn't pro competition.. only amateur..
i always use halmet on Track.. just for the weekend use i don't  _________________ 79' 924 2.0 @ Estoril Track |
Posted: Fri Sep 12, 2008 12:32 pm Post subject: |
aaaaaand that is exactly what you don't want to have on the street. You will smack your melon on the bars (the padding is only good in combination with a helmet)
Even amateurs need good equipment. A poorly built and installed cage can do more damage than good. I would go talk to the folks in the 924 Racing section as they are actively using cages and safety equipment for their amateur racing. _________________ Stefan
skemcin
Posted: Fri Sep 12, 2008 1:18 pm Post subject: |
I vaguely remember a member telling a story of their own about getting knocked on the nugget because he was driving a full cage car on the street (without a helmet).
edit:
this isn't what I was thinking, but a good example nonetheless. _________________ 924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
