Bearings Query
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board
Guest
PostPosted: Wed Mar 01, 2000 12:53 am    Post subject: Reply with quote
Email: rameshm_007@yahoo.com
Date: 01 Mar 2000
Time: 01:53:16
My 924 was modified with a 944 Turbo look. Additional spacers were added to accomodate the wider wheel arches.
Someone has warned that the additional spacers would add additional stress to the bearings (inner and outer), and might cause premature wear.
Need advise on :
1. Is the warning valid ?
2. If answer to 1 is yes, what can I do to reduce the stress ?
3. Any other possible problem areas that I should note ?
Thanks !!
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    924Board.org Forum Index -> Posts Rescued From the Old Board All times are GMT + 10 Hours
