Chickenwing
Posted: Fri Aug 22, 2008 7:19 am Post subject: after smoking ballast resistor ... coil ohm readings |
so after having trouble starting the car and the right ballast resistor smoking while finally running(never for long) im testing the coil to see if its shot
the allowable readings per Haynes:
(terminal 1&15) 1.0 to 1.35 Ohms
(terminal 1&4) 5.5 to 8.0 kOhms
My coil readings are 1.5 Ohms and 7.42 kOhms, respectivly.
Is this too far out of range for the coil to be good?
Btw im pretty sure the coil is original(car has 62k miles) and on the bottom the numbers "0 221 122 008", "627", and "KW 12V" are stamped. _________________ 1977 924 4-speed |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Fri Aug 22, 2008 7:25 am Post subject: |
the first reading is above specs and should just be changed because of that and the 2nd reading is rael close to foobar replace it _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Chickenwing
Posted: Fri Aug 22, 2008 7:38 am Post subject: |
thank you. nice and simple.
would going with a non oem(aka non-bosche) coil be ok? my local autoparts store has some coils in the $50-80 range or i can get a MSD Blaster2/3 coil.
i did some research but no clear answers, only mentions of it not being worth as an upgrade. _________________ 1977 924 4-speed |
Posted: Fri Aug 22, 2008 12:27 pm Post subject: |
When dealing with low ohms readings always short the leads together to check the meter reads zero first.
(my leads read 2 ohms on their own)
You have to subtract any reading you get from the total if you cant 'zero' the meter.
Also take into account any corrosion and clean the spots you are testing.
As for the coil, you have to go genuine or similar. _________________ Porsche 924 1984 (UK import) NA
RC
Posted: Fri Aug 22, 2008 12:59 pm Post subject: |
+1 to ^ re meter leads.
Your coil is probably fine IMO.
A generic resistor type coil should be OK too but take your meter with you and ensure the primary resistance is NOT LOWER than spec. The MSD coil probably will be and likely blow your TIU. |
Chickenwing
Posted: Fri Aug 22, 2008 10:19 pm Post subject: |
hmm well it seems the leads do have .1 ohms of resistance.
time to check the rest of the stuff i guess ... _________________ 1977 924 4-speed |
Chickenwing
Posted: Fri Sep 05, 2008 8:20 am Post subject: |
well i checked the rest of the electrical system and everything gets the correct readings ...
does the grounding cable to the battery usually get hot when u try to start the car?????? _________________ 1977 924 4-speed |
Posted: Fri Sep 05, 2008 8:33 am Post subject: |
On other cars, no. I'm not sure about the Porsche. To me that indicates a lot of resistance to current flow. I would probably replace the battery cables. Then clean and grease all of the connections in the engine bay. Make sure to clean the battery post connections as well.
Good luck! _________________ Stefan
Chickenwing
Posted: Sat Sep 06, 2008 3:43 am Post subject: |
well i am now certain it is not a electrical problem. everything has been tested.
It might be a fuel issue ...
upon cranking no fuel shows up at the 5th injector located on the side of the intake manifold(cold car).
the fuel pump also receives only 10.7volts while cranking.
how can i tell if the fuel pump relay is bad?
any other help? _________________ 1977 924 4-speed |
Chickenwing
Posted: Sat Sep 06, 2008 7:26 am Post subject: |
post 31 & 87 on the fuel pump relay ... are they supposed to be continuous ... meaning i should be able to have the meter beep when i test the 2 posts? _________________ 1977 924 4-speed |
77Porsche924
Joined: 28 Feb 2008 Posts: 168 Location: Aldergrove B.C.
Posted: Tue Sep 09, 2008 1:26 am Post subject: |
Chickenwing,
This may or may not be helpful... but here's what i know from this weekend's fun... (amusing story here)
I have a parts car and the main project.
When i took the fuel relay from the parts car (cuz it looked newer than my car's original one, eg: no rust) and put it in my car, ignition on, i could not hear the fuel pump.
When I took the original covered in rust and shoved it back in, BINGO! Fuel pump, pumpin' away.
Then i wasn't sure if I was getting fuel to the injectors, so... since it was so damned hard to get the injectors into the new inserts, i decided why not pull one of the banjo bolts from the fuel dizzy... SPISSSSHHHH...
IN DA FACE!
Fuel everywhere!
Yup, pressure in the fuel lines... they work!
<Grin> _________________ 1977 Porsche 924
Classified Car Tips It's like the bible for craigslisting. |
Chickenwing
Posted: Tue Sep 09, 2008 12:42 pm Post subject: |
hmm. i dont have a parts car and i wonder how hard it'd be to get a new fuel pump relay. i guess thats the next step. _________________ 1977 924 4-speed |
