924S external oil cooler help
Fast924S
PostPosted: Thu Jul 17, 2008 2:15 pm    Post subject: 924S external oil cooler help Reply with quote
Hey guys, I know 99% of you guys run the 924 with the 2.0L But Im hoping someone can help me, Im trying to find a place to install a 951 external oil cooler but its very hard to find a spot on the 924 body, Any of you guys got pics of your external oil cooler setups??? I need ideas. Thanx
Rebuild COMPLETED, Many mods, better power, Just ask for info
PostPosted: Thu Jul 17, 2008 3:14 pm    Post subject: Reply with quote
You could buy a 931 valence and put it in the 931 location. Seems like I also saw a pretty good kit for this, but I can't find it now.
PostPosted: Thu Jul 17, 2008 9:22 pm    Post subject: Reply with quote
Recommended reading:
Oil Cooler Location? - and install updated with Pictures
Oil Cooler, where to place?
How to install an aftermarket oil cooler
None of the information presented in those threads is necessarily specific to the 2.0L, other than I believe you may need a different thread on the oil filter sandwich adapter for the 2.5L. Otherwise, installation techniques and location options should be essentially identical.
p-talk
PostPosted: Fri Jul 18, 2008 2:58 am    Post subject: Re: 924S external oil cooler help Reply with quote
Will this be in addition to the water-to-oil stock cooler, or are you bypassing that unit somehow?
1984 Porsche 944
1990 Audi 200 TQA
1990 Audi 90S
PostPosted: Fri Jul 18, 2008 3:03 am    Post subject: Reply with quote
He's replacing the stock oil console with one from a 951. This eliminates the oil/water matrix.
p-talk
PostPosted: Fri Jul 18, 2008 5:21 am    Post subject: Reply with quote
Sweet. I always thought that contraption was a poor and unreliable solution to oil cooling
1984 Porsche 944
1990 Audi 200 TQA
1990 Audi 90S
Fast924S
PostPosted: Fri Jul 18, 2008 3:11 pm    Post subject: whoaaa Reply with quote
Yes, I have swapped the 924S oile cooler housing for the 951 cooler ousing
John Brown
PostPosted: Fri Jul 18, 2008 10:06 pm    Post subject: Reply with quote
Yes and no.
It's a very good system for a street driven vehicle which needs to warm up a rapidly as possible in widely variable temperature conditions. To my mind it should be thought of as an heat exchanger (as it would be labeled on the almost 100% of jet engines with similar units).
Note with interest that Porsche only changed the system in the turbo. Traditionally an application with LOTS more heat to get rid of.
I think I'd keep it running a street car unless my home was in a very hot region. I do try to find the turbo housing to install on race motors. Not easy as they are most often priced at silly numbers.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
Fast924S
PostPosted: Wed Aug 06, 2008 8:14 am    Post subject: Reply with quote
Ok, So I relocated the horns and installed the cooler on the Drivers side, Got the hoses installed. Now I just need to modify the lower valance for better air flow
[img]
[/img]
Martijnus
PostPosted: Wed Aug 06, 2008 8:49 am    Post subject: Reply with quote
Mine is placed in front of the coolant radiator... and turned 90degrees... so it's about 5" to the right, compared to your location..
can't tell how it works, but it couldn't be in a better air flow and I didn't have to adapt any valance.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Fast924S
PostPosted: Thu Sep 04, 2008 8:54 am    Post subject: Reply with quote
Ahh Yes, The down side to your setup is that fact that all the hot air from the oil cooler is being picked up by the RAd and back into the coolant system and into the engine, You Just make almost the same kinda setup the Porsche used stock. The way I have it wont tax the cooling system as it has its own air flow and the heat from the rad and the oil cooler stay seprated thus making it more efficient. So far its been running fine, Temps havent gone over the half mark when driving, Oil pressure stays between 3-5 bars depending on temp
Scorpio
PostPosted: Thu Sep 04, 2008 11:57 am    Post subject: Reply with quote
ide be guessing that with a GT front bumper you couldnt have the oil cooler in the horn or windscreen washer tank section as the Gt bumper has no venting to this area or am i missing something?
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
