Email:
Date: 29 Feb 2000
Time: 22:49:14If you tow it from the back you just have to be careful of dips since the nose will nearly be scrapping the ground, of course the steering will need to be locked. If you tow it from the front, you have to watch out that you don't hit anything important with the tow dolly, and it might be good to remove the cv axles on a long tow, the concern is that the bearings in the trans will not recieve lubrication and will eventually heat up and gall. This can happen on some cars, whether a 924 has trouble I don't know.
