Fuel Accumulators????
HEMBRANT12
PostPosted: Fri Aug 15, 2008 9:46 am    Post subject: Fuel Accumulators???? Reply with quote
Does anyone know if there are other cars that use the same fuel accumulator or compatible accumulators. I'm getting an NA 80 924 back together and am in the process of rebuilding the fuel lines. The accumulator looks shot, but replacements seem a bit steep, just wondering what my options are.
1988 Porsche 924S
1970 VW Karmann Ghia
1971 VW Super Beetle
2007 VW Rabbit
wombat
PostPosted: Fri Aug 15, 2008 5:31 pm    Post subject: Reply with quote
three questions
One: did you unscrew the screw on the bottom a little and see if fuel came out? If it does then its stuffed
Two: Do you have 2 accumlators or one? (someone will probably know because of the year but I dont)
Three: how much is steep?
1977 924 2.0 Auto
924guy
PostPosted: Fri Aug 15, 2008 11:25 pm    Post subject: Reply with quote
pretty much screwed if you need new accumulator(s) as far as replacements go, easy to spend several hundred on them and not many alternatives. However,rumor has it certain mercedes accumulators are of similar spec, though not direct, fittings are different. If you swap out the fuel lines id bet something could be cobbled together to work.
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
wombat
PostPosted: Sat Aug 16, 2008 12:20 am    Post subject: Reply with quote
This woul not supprise me, I have noticed a few other thingss on Mercedes at the self serve wrecking yard that look like they would fir the 924 with little or no mod so maybe this is worth a try.
1977 924 2.0 Auto
PostPosted: Sat Aug 16, 2008 2:42 am    Post subject: Reply with quote
What about a home-made accumulator? Could you just put a sealed piece of pipe in the fuel line like plumbers do for water supply lines? Seems to me this would do the same thing as an accumulator, but it's easily within the realm of cheap DIY'ers.
To use parts all rated for fuel system use, I could easily imagine a T-fitting, with the base of the T pointing upwards into the bottom of a fuel filter, with the top of the fuel filter capped. The air within the fuel filter would act as a spring to maintain fuel pressure with the pump off. If there's insufficient volume, a 2nd could be used. It's a great use for old fuel filters!
A filter body with the elements removed would be preferable of course. . .
78 924 NA
5-lug
Chrenan
PostPosted: Sat Aug 16, 2008 5:02 am    Post subject: Reply with quote
The accumulator has an internal rubber bladder that holds pressure in the system after shutdown (aids in hot starts) and smooths fuel flow. When the bladder ages and rips, it leaks fuel, hence when you loosen the screw on the bottom of a failed accumulator fuel drips out. Making one may be slightly outside the skills of the average home mechanic.
HEMBRANT12
PostPosted: Sat Aug 16, 2008 6:04 am    Post subject: Reply with quote
It's definately shot, I took the screw out and fuel ran out for a good 30 seconds. Looks like I'll be getting a new one
1988 Porsche 924S
2007 VW Rabbit
michi924
PostPosted: Sat Aug 16, 2008 6:35 am    Post subject: Reply with quote
Hello Hembrant. I bought one of those at Autohaus Arizona a few weeks ago. Thay had te best price I found in Internet.
Porsche 924 NA Euro.
michi924
PostPosted: Sat Aug 16, 2008 6:36 am    Post subject: Reply with quote
Sorry. I forgot the link:
http://www.autohausaz.com/
924guy
PostPosted: Sat Aug 16, 2008 11:01 pm    Post subject: Reply with quote
65.89 and 97.30 depending on return line or not at the above link, excellent prices...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
968rz
PostPosted: Sun Aug 17, 2008 11:25 am    Post subject: Reply with quote
How come mine is $210 ?
0438170024
Bosch
Fuel Accumulator
1 per car. $210.44
Rick
93 968 coupe Amazon Green 4spd Tip (my DD)
datatrain
PostPosted: Sun Aug 17, 2008 2:55 pm    Post subject: Good prices Reply with quote
Those guys have excellent prices. Alternators and starters are cheap compared to what I usually see.
Another place I found that has reasonable prices is the PartsBin.com Got a complete exhaust system 183 bucks
'78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
PostPosted: Sun Aug 17, 2008 10:23 pm    Post subject: Reply with quote
Fuel accumulators for cars up to 1978 are about $100 then for 1979 onwards the price jumps to around $250. No idea why the jump n price but the AutoHaus Az prices are still amongst the best.
PostPosted: Sun Aug 17, 2008 11:32 pm    Post subject: Reply with quote
I agree about Autohaus, but when I must obtain anything from a dealer, I call or email these guys. They usually beat my local guy by 30% or more:
Sunset Porsche phone 1-800-346-0182
attn: Jeff Clark fax 1-503-601-3090
4030 SW 139th way
Beaverton OR 97005
Parts department hours: Pacific Time
Mon-Fri 8-6 Saturday 9-12 (3 hours)
Closed Sunday
secure order form link to place an order:
http://www.sunsetimports.net/sorder.php
Sunset Imports website:
www.sunsetimports.com
RC
PostPosted: Mon Aug 18, 2008 12:31 am    Post subject: Reply with quote
The early 924s have two of 20cc accumulators while the later (79+) have only one 40cc unit. Still no justification for the vast price difference though.
