Jay Rome
Joined: 23 Mar 2007 Posts: 5 Location: Savannah, Georgia USA
Posted: Tue Jul 15, 2008 7:47 pm Post subject: 931 "rubber" fuel lines |
I have searched for these quite a while, the two (supply and return) fuel lines about three feet in length that connect to the fuel distributor. Anyone replaced these and most important where did you get them?
Mine are very cracked (at least the outer covering). Thanks in advance. _________________ Jrome |
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Tue Jul 15, 2008 11:48 pm Post subject: |
Did you try the Porsche dealer? _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Posted: Wed Jul 16, 2008 12:37 am Post subject: |
Check the yellow pages for a hydraulic shop near you. They should be able to fab up some SS lines at a reasonable price, or even rubber ones. _________________ Toofah King Bad
Posted: Wed Jul 16, 2008 1:12 am Post subject: |
The outer rubber sleeve is just to protect the inner tubing. Just an idea...you could probably fabricate cheap replacements using off-the-shelf small diameter rubber or silicone hose by cutting them longitudinally and slipping over the inner tube (similar to how those plastic wiring harness protectors work). _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jul 16, 2008 11:30 am Post subject: |
Heat shrink tubing works well... _________________ White 87 924S "Ghost"
