205 60 tyres
Zermatt924SUK
PostPosted: Tue Jul 15, 2008 7:44 pm    Post subject: 205 60 tyres Reply with quote
What benefits (if any)Would I get from changing my 195 65 to 205 60?
Has anyone 205 60's on the rear..I'm only changing the rears..The wheels are 15inch
1988 924S Zermatt Silver
PostPosted: Wed Jul 16, 2008 1:08 am    Post subject: Reply with quote
Those 65s are not the correct size for your S, and you may be better off waiting until you can change all four. . .the change in aspect ratio you should be pursuing probably shouldn't be mixed with 65s up front.
Our S has 205/55. They work and look great (clicky):
As for benefits, if you switch to this size you will see a substantial improvement in handling. . .guaranteed.
Zermatt924SUK
PostPosted: Wed Jul 16, 2008 1:39 am    Post subject: Reply with quote
Thanks....
alexvex
PostPosted: Wed Jul 16, 2008 2:25 am    Post subject: Reply with quote
I had 205/60/R15's on all courners of my S (Potenza G009's) and they were great. I didn't have 195's to begin with though, so I can't compare to those.
--Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951
mhart
PostPosted: Thu Jul 17, 2008 10:04 am    Post subject: Reply with quote
My 924S had 195/65r15's on it stock. Changing the tires to 205/60 r 15's would likely give you a little bit more rubber on the road and slightly stiffer sidewalls. I think though that a significant part of the change caused by changing the tires like that would come from simply getting different brand/model of tires (ie changing from all season tires to high perf. summer tires)
'87 924 S - No sunroof and a few modifications
skytrooper
PostPosted: Thu Jul 17, 2008 12:21 pm    Post subject: Reply with quote
I have 205 / 55 / 15's on all 4 corners of my S. They look great and perform even better
Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone)
Speedtek
PostPosted: Sat Jul 19, 2008 2:50 pm    Post subject: Reply with quote
My car came with 185/65R15 Goodyear Tires. I was getting 30 mpg but they sucked as far as handling is concerned. The threadwear on the side is 480. I put on some 205/60R15 Federals and now I get 28 mpg. But they look a lot better.
I think I have turbo'ed everything!
