wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Thu Jun 19, 2008 8:35 pm Post subject: a few more things I need help with |
hi all the 77 auto is coming along nice almost back on the road.
I have a few more questions though.
LIGHTS:- I have the parking warning lights on (front and rear LHS lights to warn that the car is parked), How did i turn them on and how the F do I turn them off??? I now have a flat battery partly because of other things too.
The other lights question I have is about the back of the speedo, there is a black 4 way wire joiner that i dont think is ment to be there and when i moved something back there I got a short and now when my lights are on the dash lights and the lights from the aux guages dont work but instead I have my turn signal light come on (short somewhere between dash wire and turnsignal wire) could this be because the 4 way screw thing is not ment to be there and some one like the PO (who has done other crapy wireing in this car and loves these joiners that you just tighten the screw instead of using solder like a real electrical repair!!!) has rewired things crappy.
HOW DO I GET THE ENTIRE CLUSTER OUT TO CHECK? IS THERE A WAY TO DO IT WITHOUT TAKING THE WHEEL OFF?
I HATE OPP's ELECTRICAL WORK (ALWAYS USE SOLDER, THE RIGHT COLORS, AND DO A NEAT JOB THAT CANT SHORT PLEASE, JUST INCASE I EVER END UP WITH YOUR CAR)
REAR OF CAR:- I have this funny emblem under the rear hatch lock it looks like a castle and a deer or something like that, is this original? _________________ 1977 924 2.0 Auto |
Posted: Thu Jun 19, 2008 9:48 pm Post subject: |
My lights were on the other day for no reason I could tell.
The daughter had the left indicator switch still on.
Must have been some feedback somewhere. _________________ Porsche 924 1984 (UK import) NA
Rich H
Posted: Thu Jun 19, 2008 9:53 pm Post subject: |
My car is wired with parking lights.
If you switch off the ignition then select the indicator one way or the other (Or vice versa), the parking lights on that side come on.
I think its a requirement for Germany? _________________ 1994 Lotus Esprit S4 - Work in progress...
guidon113
Posted: Thu Jun 19, 2008 10:41 pm Post subject: |
Does the emblem look like this
http://en.wikipedia.org/wiki/Image:Wappen_Wolfsburg.png
If so, I can not find any indication of a Wolfsburg Edition Porsche.
Tiny
Posted: Thu Jun 19, 2008 10:50 pm Post subject: |
Ohhh...I always thought that I had a short with the wiring...when the indicator was left on...but now I see that the fault is called german parking lights.
thanks man...i dont even want to think about what i would have done if i hadn't just learned that.
tiny _________________ *****1981 - 924 - Auto - London, UK****** |
wombat
Posted: Wed Jun 25, 2008 8:28 am Post subject: |
yep this is the emblem? should I keep it? does it mean anything?
thanks it was the indicator stick on? I knew that it was the parking likghts just not how to turn them on, after this I realised 2 other cars I drive have this feature that works in the same way.
I took the wheel off rewired the dash cluster corectly without the stupid screw wire conector then put it back in, everything works great, however I now have a black and yellow wire with a spade conector on the end of it without a place to put it and cant find anything not working??
the other thing I now have is a strange problem with my lights, they go up fine on off, acc and start but only close on acc or start, when you try to close them on off they keep cycling going up and down, this has happened only once when it is on acc but every time the car is off??? this may be connected to the last wire missing but cant find anything to suggest this.
I also tried replacing my heater core with the correct one because the PO had installed an incorrect one that was blocking the flap and not allowing selection of air direction, however after much trying I have found that you need a flange for the heater core to make the barbs stick out the firewall and this is missing from my car. The PO must have removed it when he instlled the incorenct heater core. Great back to the parts shop this weekend in the hope of finding a flange.
One last thing I have been thinking of removing the distributor for a few reasons mainly because one hose clamp going to the heater core (the modified very dodgey one that consists of heater hoses inside the car) is turned so I cant get to it with the distributor in the way.
I have noticed that it does not seem to run an oil pump is this correct?
also I need to time it properly anyway because the enging is pinging.
Is the distributor install procedure to:
get the engine to TDC and install the new distributor, then statically time it to the timing line, then dynamically time it using a light?
does anyone have any suggestions or help with timing settngs?
what does the TDC mark look like in the RestOfWorld cars as I have noticed that the US marks are different to ROW marks? _________________ 1977 924 2.0 Auto |
guidon113
Posted: Wed Jun 25, 2008 9:12 am Post subject: Ferdinand Porsche SR |
There is History with Porsche and Wolfsburg however, I dont believe Porsche ever released a Wolfsburg Edition 924. It is likely that the previous owner was familiar with the relationship between Father Porsche and VW Wolfsburg, and put this badge on for fun. Any other thoughts?
http://en.wikipedia.org/wiki/Ferdinand_Porsche |
Rich H
Posted: Wed Jun 25, 2008 9:32 am Post subject: |
TDC mark is on the fly wheel look through the little window to the RHS while looking at the bell housing.
You are looking for
There are also +10 and -10 marks these are 10 deg BTDC and ATDC (Yes they are the wrong way round, you'd have to ask Audi why!!) _________________ 1994 Lotus Esprit S4 - Work in progress...
RC
Posted: Wed Jun 25, 2008 12:48 pm Post subject: |
Think that black/yellow wire is for an EGR light (or similar) that we don`t have here. Shouldn`t affect the pop ups. They can be a PITA. Recheck whatever you did, then check the relay on the motor then clean and/or wiggle the terminals and the wire connector. Possibly the switch contacts or faulty diode on the motor but unlikely if it was OK previously.
Oil pump is at the front and drives direct from the crank, no connection to the dizzy. Usually line flywheel to TDC or +10 (timing mark, BTDC) with rotor at #1. Mark line at dizzy base and housing and note rotor position before pulling dizzy out. Easy then to replace quite close before setting with timing light. Stock ROW is 10 BTDC initial with vac line disconnected. Should pick up a little more power by further advancing to 15 initial with no problems.
Roger |
wombat
Posted: Fri Jun 27, 2008 4:17 am Post subject: |
guidon: my only problem with this theory is that the badge would have had to been put on very early in the cars life as it is very old and worn and this car has only had one other owner besides myself who purchased it new. I just dont think he would have done something like this as he was 86 when I purchased the car from him a month ago.
Rick H: thanks for the info this will help alot
RC: Thanks heaps for the 15 degree and other info exactly what I was looking for. _________________ 1977 924 2.0 Auto |
Rich H
Posted: Fri Jun 27, 2008 4:38 am Post subject: |
first thing to do is put the engine at TDC and find all the marks. Clean them up and fill them with whire paint so you can see them easily, make sure you can identify them too, as in tell +10 0 -10 while timing.
If it turns out that you can't find them when tuning, as in you turn the dizzy both ways until it stumbles and still can't see them, it is possible that the flywheel has been put on wrong. Makes things extra tricky... _________________ 1994 Lotus Esprit S4 - Work in progress...
wombat
Posted: Tue Jul 01, 2008 9:47 am Post subject: |
ok ok ok,
fixed most of this, but have a series of new problems that I now need a hand with.
ONE: the light that is in the auto shifter to light up the gear you are in where does it sit I cant find a spot that it fits and seems right.
TWO: I have a switch in the console behind the shifter (after removing the ones that I knew were stupid add ons) this one that is left runs to a light that doesnt seem to work but is in the same spot as the shifter light I just talked about and then it goes to a black and white wire that is part of the original wiring running from near the shifter to behind the stereo din hole and then into the black hole (I cant chase it any further) any ideas.
THREE: does anyone know where I can get a decal for my auto shifter it has a spot for one but nothing is there. _________________ 1977 924 2.0 Auto |
Rich H
Posted: Tue Jul 01, 2008 10:17 am Post subject: |
I think that #2 is the front fog lamp light, is it a blue bulls eye type light? _________________ 1994 Lotus Esprit S4 - Work in progress...
wombat
Posted: Wed Jul 02, 2008 9:00 am Post subject: |
| Rich H wrote: | | I think that #2 is the front fog lamp light, is it a blue bulls eye type light? |
no, not really it is just like the standard dash lights but with an earth wire.
It sits under the auto shifter housing with the auto shifter light that I cant find a place for and you cant see it when it is on.
The light looks like an add on, repair or replacement but from this point it runs to an original wire which runs back in a tight group with all the other original wires (it is pretty obvious in this car what wiring the PO did as it is shitty, and all over the place, all the original wiring is taped together in thight bundels and looks neat and tidy).
Confused by this one as the switch appeasrs to do nothing??? _________________ 1977 924 2.0 Auto |
wombat
Posted: Wed Jul 09, 2008 7:10 pm Post subject: |
I found out about that funny badge on the back today. Apparantly it was fitted to all (australian at least) early 924's that were fitted with the optional handling package which included passengers outside mirror, alloy wheels, 18mm sway bar up front and 20mm sway bar at the rear all of which my car has. needed to get a part from the porsche dealer so I asked the guy didnt know but he pointed me to a sales guy who had clocked 35 years selling porsche's and problem solved.
now I also have a question if anyone is still reading this thread.
I adjusted the rear shoes and that was fine, then I went to get the front wheels off to do the rotors and pads which I have had sitting here for a while but have not gotten around to doing, and I couldnt. I have tried a breaker bar, a longer breaker bar and then worried a little, any ideas, I can apply more torque with a geared wrech setup but last time I tried this on a car I broke the socket before getting the nuts loose. I dont know who last worked on the wheels or I would take it back to them, I also have an impact gun but was reluctant to try any more incase I was turning the wrong way.
Final option I can see is if the bolts only enter the rotor I could either do some very fast stop start driving to heat up the rotor and try again or I could just drill the heads off replace the rotors with the ones I have, and get new lug bolts.
because these are bolts not nuts do they turn any differently or is one side reverse thread, or have I just been mistaken that you should turn bolts anticlockwise to loosen. _________________ 1977 924 2.0 Auto |
