Starter won't disengage
skytrooper
PostPosted: Sun Jun 15, 2008 9:37 am    Post subject: Starter won't disengage Reply with quote
I have replaced the solenoid and it worked fine a couple of times. Now it is back to staying engaged even after the engine starts. I have to pull the battery terminal to make it quit. Does this starter require some shimming that is missing ?
Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone)
PostPosted: Sun Jun 15, 2008 1:59 pm    Post subject: Reply with quote
Check your ignition switch.
skytrooper
PostPosted: Sun Jun 15, 2008 11:29 pm    Post subject: Reply with quote
Well whattya know ! It was cracked at the little pin.
Now I just have to find a switch
Thanks Paul
Matt
1982 - BMW 633CSi
1984 - BMW 528e
skytrooper
PostPosted: Fri Jun 27, 2008 9:20 am    Post subject: Reply with quote
still a NO-GO in this area. I have replaced the ignition switch and the starter solenoid. I am a little confused on what to try next
Matt
1982 - BMW 633CSi
1984 - BMW 528e
RC
PostPosted: Fri Jun 27, 2008 11:27 am    Post subject: Reply with quote
Hook up a meter to the solenoid coil, #50 IIRC, and see if there is voltage when its running on. 12V (nom) means possible shorted wire loom to starter, faulty switch again, or some feedback/connection on the #50 line.
No voltage to the primary indicates the solenoid is jamming or shorting internally or the arm to the bendix drive is locking up, or similar.
Check all your wiring is correct and not bridged at the solenoid or starter. Especially the terminal and wire to the coil, if wired wrong you will latch the solenoid on with the ignition.
Roger
tuurbo
PostPosted: Fri Jun 27, 2008 11:51 am    Post subject: Reply with quote
It won't hurt to have some insulating grease around the nuts holding the wires in place.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
