Cutting springs
Dutch924-racer
PostPosted: Thu Jun 12, 2008 6:07 am    Post subject: Cutting springs Reply with quote
Strange enough one of my springs has broken today.
I have a trackday this weekend and can't get new lowered springs that fast.
I am going to cut my original springs temporarily.
I want to lower about 1,25 to 1,5 inch (3 - 3,5cm)
How may rings do I need to cut of 1/2 or 1 or 2 ???
many thanks.
924 2.0
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Thu Jun 12, 2008 6:23 am    Post subject: Reply with quote
The best way to know is to look at your car and measure it.
With weight on your springs (that is, car on the ground), look at the springs and mark where you want the car to be.
Cut off a little more than that, since cutting your spring will increase its rate. So, if you want to cut off 10% of the spring, increase the amout you cut off by an additional 10% (so, cut off 11%) in order to get the final height right.
78 924 NA
5-lug
Martijnus
PostPosted: Thu Jun 12, 2008 7:30 am    Post subject: Reply with quote
I've seen it done by exposing the spring to large amounts of heat (gas torch)...
but I guess that #### your spring constant...
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Thu Jun 12, 2008 10:38 pm    Post subject: Reply with quote
You should switch to standard size racing springs... 2.5"x8" here in the US, not sure what sizes are normal over there except I think 60mm is too small for some adjustable height collars...
924turbo_sout_africa
PostPosted: Thu Jun 12, 2008 11:02 pm    Post subject: Reply with quote
well i did this to my golf gti this had in the same springs as a 924 and we cut off 1/2 to almost 1 and that gave me about a 40mm drop
Porsche ...where dreams are a reality
'79 924 turbo canada spec
'98 Formula Vee (M3 eater)
Time in the 931 is a dream come true !!
