incognitokc
Joined: 03 Jun 2008 Posts: 19 Location: hazel park michigan usa
Posted: Wed Jun 11, 2008 9:16 am Post subject: this is a good one.. ignition/ starter issues on my 1980 931 |
i took my 931 out for a quick drive after work today drove it about ten minutes or so came back home pulled into the garage shut it off, just for the hell of it decided to start it back up and the starter stayed engaged after the car started so i shut the key off and the car stayed running and the starter stayed engaged so i put it in gear with foot on brake and let the clutch out to stall it but it just kept trying to start so i put it in 5th gear and engaged the e brake and tried to get the battery cable undone the whole time it was still trying to start by the time i got the cable unhooked i had a big cloud of smoke and that burned electronics smell all coming from the back side of the engine (kind like where the starter is) i forgot to add the whole time it was doing this i tried putting the key in and out off and on thinking the ignition was stuck, but i think something else was going on now i probably fried the starter and maybe some other things ...what do you guys think? let me know
thanks....ken |
Posted: Wed Jun 11, 2008 10:17 am Post subject: |
Probably a stuck starter solenoid. _________________ White 87 924S "Ghost"
Posted: Wed Jun 11, 2008 11:03 am Post subject: |
I'd second that frozen solenoid theory - if stuck in the engaged position it would not only continually operate the starter and turn the engine, but also provide the ignition with power to run through it's #16 post.
If you were successful at stopping the engine and starter by putting it in gear and engaging the e-brake, then the electrics burning smell was the starter and/or the heavy gauge wires to being roasted.
Power to the starter comes directly from the battery. Once the solenoid is engaged, power to the 16 post also comes directly from the battery - http://www.pelicanparts.com/944/electrical/924_78_1_1.jpg _________________ "..it's made in Germany. You know the Germans always make good stuff."
incognitokc
Posted: Wed Jun 11, 2008 11:31 am Post subject: |
| so if i take the starter and have it rebuilt5 i should be ok? |
incognitokc
Posted: Wed Jun 11, 2008 11:33 am Post subject: |
| that makes a lot of sense i have had a couple of times where the starter just clicks and doesnt turn over in the last 2 weeks |
Posted: Wed Jun 11, 2008 11:48 am Post subject: |
Get another one don't even try to have it rebuilt. _________________ White 87 924S "Ghost"
Posted: Wed Jun 11, 2008 11:53 am Post subject: |
$100 at your local parts store _________________ White 87 924S "Ghost"
Posted: Wed Jun 11, 2008 11:55 am Post subject: |
I would also replace the heavy cable that runs from the positive post of the battery to the starter solenoid. _________________ White 87 924S "Ghost"
incognitokc
Posted: Wed Jun 11, 2008 12:40 pm Post subject: |
im not to fond of non factory replacement parts, besides there is a company that ive been dealing with for 18 years that all they do is rebuild starters and alternators, and ive never had any problems
i would rather have mine revamped than buy some cheap autozone starter |
Posted: Wed Jun 11, 2008 1:11 pm Post subject: |
Your choice, but if it smoked be prepared for your rebuilder to laugh.  _________________ White 87 924S "Ghost"
Posted: Wed Jun 11, 2008 1:15 pm Post subject: |
With the 931 you have more starter options open to you. The 944 starter fits, spins in the same direction, is a bit smaller, lighter, and cheaper.
The solenoid being stuck is still only a most-likely, educated guess - there's at least a small possibility that it's an ignition switch problem. They're cheap enough that I'd replace it too, even if it's not the problem, if you don't know how old it is (rather than wait for it to strand you somewhere). _________________ "..it's made in Germany. You know the Germans always make good stuff."
incognitokc
Posted: Wed Jun 25, 2008 8:28 am Post subject: |
i just went out and reconnected battery and it started just like normal
this thing is goofy! |
skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Wed Jun 25, 2008 9:51 am Post subject: |
it will probably happen again real soon. Mine had been doing the same thing. I replaced the solenoid...still had problem. I replaced the ignition switch...still have the same problem. I decided to try shimming...still had the problem. So now the starter is in the shop to see what the heck is going on.
I never had the burning smell and I could always turn off the motor. I just had to pull the battery terminal to make the starter stop _________________ Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone) |
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Fri Jun 27, 2008 12:22 pm Post subject: |
This sounds kooky and I've given the same reply on a couple of other threads but I had real wonky starter issues on my 931 - sticking on and not starting. Seems there was a short - put some insulating grease on the nuts and everything is fine. Been that way for months now. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
