Zermatt924SUK
Posted: Fri May 09, 2008 4:21 pm Post subject: Window Switch |
| Are the Driver and passenger window Switches the same? |
Posted: Fri May 09, 2008 4:39 pm Post subject: |
| Yes they are. |
NBRettie18
Joined: 21 Jan 2006 Posts: 111 Location: Santa Barbara, California
Posted: Sun May 11, 2008 8:54 am Post subject: |
my drivers side is broken or something. when i roll the window up it doesnt stop at the top it just keeps going up and smashing into the top and bouncing down its really annoying and cant be very good. has anyone ran into this problem or know what could be the issue.
thanks _________________ 1987 924S - MO30 30/19 - Yellows all around |
Posted: Sun May 11, 2008 9:27 am Post subject: |
Replace or repair your switch. You could swap one of the passenger side switches until you get another one. _________________ White 87 924S "Ghost"
bcblase
Posted: Sun May 11, 2008 10:57 am Post subject: |
Neither of my windows will go up or down now - damn gremlins!
BC _________________ 1987 Porsche 924S - track toy
Posted: Sun May 11, 2008 12:19 pm Post subject: |
| ucrackaass wrote: | my drivers side is broken or something. when i roll the window up it doesnt stop at the top it just keeps going up and smashing into the top and bouncing down its really annoying and cant be very good. has anyone ran into this problem or know what could be the issue.
thanks |
This one sounds like a regulator or motor gear problem. If pressing the up part of the switch moves the window up, and pushing the down moves it down, then the switch is doing what it's supposed to. A broken or loose gear, or possibly the whole motor or regulator is loose...something like that might cause your symptoms. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sun May 11, 2008 12:29 pm Post subject: |
| bcblase wrote: | Neither of my windows will go up or down now - damn gremlins!
BC |
The motors and the switches seem to be the main problem areas with the power windows (another possible problem area would be wiring and connections at the fuse-relay panel, and the relay, but I haven't had any trouble with those). I've had both motors out, once each, for cleaning and regreasing at different times a year or so apart. -And the switches have had several cleanings. One finally stopped responding to the cleaning, so it got replaced just a few months ago. In addition to it now working reliably, the window that switch is on moves much faster.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
bcblase
Posted: Mon May 12, 2008 7:43 am Post subject: |
I cleaned the driver's side up real good and greased all the tracks and gears last winter, and it is like twice as fast as the passenger's side.
Both windows stopped working at the same time, so I expect it's a problem with the relay or fuse block. I made a jumper wire from the battery, and the motors and switches work fine on both windows.
Time to dig around under the dash again....sigh
Posted: Mon May 12, 2008 8:49 am Post subject: |
On my car, the window relay and the radio relay are clipped onto the left side of the hvac box. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Mon May 12, 2008 8:54 am Post subject: |
| bcblase wrote: | | I cleaned the driver's side up real good and greased all the tracks and gears last winter, and it is like twice as fast as the passenger's side. |
Was this difficult? How was it done? T'would make a FINE How-To.
bcblase
Posted: Wed May 21, 2008 1:55 pm Post subject: |
I'll dig around and see if I took any pics for dis-assembling the door panels and motors, etc. It was a little bit of a pain, especially the plastic lining on the inside of the panel.
The wiring diagram indicates a relay in the circuit for the windows motors, but the fuse and relay chart I have does not indicate the location of the relay on the main block.
Smoothie - where was the relay in your car?
Posted: Thu May 22, 2008 12:34 am Post subject: |
Center, 1/3 from the top in this pic -
<click>
In this case, the radio relay's the left one, and the window relay's to the right of it. _________________ "..it's made in Germany. You know the Germans always make good stuff."
NBRettie18
Posted: Tue May 27, 2008 7:30 am Post subject: |
| Smoothie wrote: | | ucrackaass wrote: | my drivers side is broken or something. when i roll the window up it doesnt stop at the top it just keeps going up and smashing into the top and bouncing down its really annoying and cant be very good. has anyone ran into this problem or know what could be the issue.
thanks |
This one sounds like a regulator or motor gear problem. If pressing the up part of the switch moves the window up, and pushing the down moves it down, then the switch is doing what it's supposed to. A broken or loose gear, or possibly the whole motor or regulator is loose...something like that might cause your symptoms. |
i took my door apart to see if i could do a quick fix, it didnt work. i think your right it must be something with the motor or the regulator. it looks pretty hard to take out of the door so im waiting till i have some time i geuss.
i took a video of it so you could see and hear exactly whats going on, heres the Link _________________ 1987 924S - MO30 30/19 - Yellows all around |
bcblase
Posted: Tue May 27, 2008 1:01 pm Post subject: |
Well, the gremlins have vacated the car (again) and the power windows now work.
I didn't do anything....weird... _________________ 1987 Porsche 924S - track toy
