Advice please from the bodywork pros *pics*
Tiny
PostPosted: Fri May 09, 2008 3:27 am    Post subject: Advice please from the bodywork pros *pics* Reply with quote
Hey all,
These bodywork blemishes have been bugging me for a little while now, so I decided to do something about it.
Thought I'd ask for some advice on how best to go about patching these areas up...
I bought the correct alpine white spray and primer....and today I set to work, uncovering a few patches of rust. I found these 4 areas that I want to fix:
A Closer look at Area 1:
Area 2 - front indicator/repeater mount:
Area 3:
Area 4 - rear wheel arch:
I've done this type of work before but only on easy flat areas such as AREA 2 and 4 in the photos above. (using body filler, then primer and then paint with wet n' dry sanding between stages)
I'm not really sure what materials to use on AREA 1, and 3 to rebuild the holes and bridge the missing/broken sections. Fibreglass putty with the fine metal mesh?!? chemical metal?
Also, on area 4 my car has a different/darker shade of white for the lower section. Where would I find the code for this colour? or should I just try and get it mixed up by the paint people (by eye), for the rear wheel arch repair.
Hope that makes sense?
Thanks everyone
Tiny
*****1981 - 924 - Auto - London, UK******
2Fast
PostPosted: Fri May 09, 2008 4:51 am    Post subject: Reply with quote
You might be able to weld a piece of metal on those cancer spots on your fender. Then I would smeer some bondo over them. Then prime & paint. It might also be cheaper to just replace the whole fender. So do some math and see which comes out ahead.
Hope this helps
=====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd
mhart
PostPosted: Fri May 09, 2008 4:58 am    Post subject: Reply with quote
I would suggest seeing if you can buy an intact front fender from a parts car or junkyard and then sanding/painting that and replacing hte one you have. Replacing it is a lot less of a hassle than filling holes is, and with rust like that, replacing the panel is probably the only way to really make it go away.
fwiw, I have a big dent and some surface rust on my pass. side front fender, and I got a fender for $75 to fix both in one shot
'87 924 S - No sunroof and a few modifications
Scorpio
PostPosted: Fri May 09, 2008 8:56 am    Post subject: Reply with quote
if youre really keen on patching 3 yourself try this
1)make sure all the rust is removed ALL THE RUST
2) bend a small peice of aluminium mesh to shape
3) tie a small piece of wire to the centre of the mesh and put a small amount of filler on two opposing sides of the mesh
4) push the mesh through the hole to the interior side of the hole, and hold the small piece of wire pulling it slightly till the filler cures and holds the mesh in place
5)fill over the mesh with body filler, sand prime and paint
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
PostPosted: Fri May 09, 2008 4:53 pm    Post subject: Reply with quote
hey...good to see you are still alive how is the new steering shaft working ?
about the body....just take the car to a body shop...they can take care of all
Tiny
PostPosted: Fri May 09, 2008 8:49 pm    Post subject: Reply with quote
Scorpio, excellent....that's what I was after. I had forgotten about the mesh being held in place with the wire in the middle! Neat.
Out of interest I took the car to a body shop and enquired about Area 1 alone....and got quoted a £200 with no guarantee it wouldn't return in a few months (of course.)
Can buy a new panel...and have it sprayed....and I might later on.....but I wanted to at least have a go myself first.
I am giving myself more work to do.....but I love it...and really enjoy working on my 924.
I recently reupholstered my seats too and will be posting a full pictorial on how I did it too real soon. Just gotta fit those carpet sides to the centre console and then take some final pics.
Hey Morghen, I managed to locate a good 924 steering shaft...with no play in the upper UJ ....hehe lucky me!
Thanks everyone
Tiny
PostPosted: Wed May 14, 2008 12:09 pm    Post subject: Reply with quote
I gotta agree with scorpio also though intact fenders are good also though you gotta worry about painting a bigger area. Ive been there.
My imput is to use light weight easy sand body filler way better than
what ya call it bondo. might tis well be usen concrete.
PORSCHEV
PostPosted: Fri May 16, 2008 9:57 pm    Post subject: Reply with quote
You guys are off your freakin rocker! Replace the fender it's junk!
You can't fix rust holes with fiber tape and bondo..thats like fixing an exhaust with black tape. It just won't hold.
If you really wanted to fix the fender properly you would have to remove it first. Once you had it off you could go to work cutting out all the rust with a zip cut. You would have to sandblast ALL other rust. Then make steel patches
to fit in the holes and WELD them in place with a mig.
All this effort would not come close to just swapping in a good fender. It would be faster cheaper and you will be MUCH happier with the result.
1978-#53 "D" track racer.
Scorpio
PostPosted: Fri May 16, 2008 10:39 pm    Post subject: Reply with quote
not all of us have the luxury of readily available fenders sitting around our back yards .... hence the bush mechanics
And FYI swapping in a replacement panel has its own problems..eg colour matching...re spraying to match paint colour and tone ....
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
PORSCHEV
PostPosted: Fri May 16, 2008 11:55 pm    Post subject: Reply with quote
FYI by the time you repair all the spots you cannot get away with not painting the entire fender anyway.
What would you do?? Just rattle can the repair areas? That would look sharp
PostPosted: Sat May 17, 2008 1:12 am    Post subject: Reply with quote
Yea that fender is toast. I rhink hes trying to work with-in his means.
with what he has & his experience level.
Frank.Ind
PostPosted: Wed May 21, 2008 4:58 am    Post subject: Reply with quote
Dont bother trying to fix the wing, it really is junk.
As for the rear, grind back to good metal. A couple of skims of filler then prime and paint.
Rich H
PostPosted: Wed May 21, 2008 6:16 am    Post subject: Reply with quote
Fenders go for £80+ over here, so its not as easy as it would first appear.
There are quite a few of us over here hanging on for cheap ones!
If its junk already you can't do any harm by trying to fix it!!
Zermatt924SUK
PostPosted: Fri May 23, 2008 2:55 pm    Post subject: Reply with quote
Including me Rich!
PostPosted: Sun May 25, 2008 4:01 pm    Post subject: Reply with quote
Tiny show some pics with whatever you decide to do.
