Straight oil cooler yes or no
Scorpio
PostPosted: Sun May 11, 2008 3:52 pm    Post subject: Straight oil cooler yes or no Reply with quote
I was looking into oil coolers for when i do my engine and turbo upgrade/rebuild. The problem is ive got a radiator, intercooler and air con evaporator all fighting for pole position, and was thinking that this sort of oil cooler might sit nicely along in that lower slot on the GT body kit bumper
http://cgi.ebay.com.au/20-ALUMINIUM-FINNED-OIL-COOLER_W0QQitemZ320248499997QQihZ011QQcategoryZ130664QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
PostPosted: Sun May 11, 2008 6:40 pm    Post subject: Reply with quote
The smallest Setrab unit would blow that thing away and be in a similar price range.
Scorpio
PostPosted: Sun May 11, 2008 10:29 pm    Post subject: Reply with quote
fair enough.... theres just so little room and so few good points to have 4 different coolers on the front of the car
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
Martijnus
PostPosted: Tue May 13, 2008 1:38 am    Post subject: Reply with quote
My guess is that the cooling surface of such a thing is wayyyyyyyy less than from a regular unit... and thus not good at all.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Tue May 13, 2008 2:23 am    Post subject: Reply with quote
Looks fine to me if you're not going to run a thermostat. If you're really wanting to manage oil temperatures, you should go for a bigger cooler and a thermostat to regulate temperatures. That thing doesn't look like it'll cool the oil much, so it's not worth putting a thermostat on it.
78 924 NA
5-lug
Martijnus
PostPosted: Tue May 13, 2008 2:28 am    Post subject: Reply with quote
so what's the use of the device then? if it doesn't cool that much...? you're just adding weight
PostPosted: Tue May 13, 2008 4:18 am    Post subject: Reply with quote
BTW, whichever way you go (I would suggest going large with a thermostat) spend some time improving the ducting of the air through the radiator, intercooler and evap. A little bit of work with some tin and some rivets and you'll improve the cooling efficiency of the systems. You don't want the air to escape around the sides of the various coolers. Obviously having a place for the hot air to go afterwards is a good idea, but first lets get all of it in the front first!
PostPosted: Tue May 13, 2008 4:22 am    Post subject: Reply with quote
Goes nicely with an electric supercharger, I guess.
78 924 NA
5-lug
PostPosted: Tue May 13, 2008 4:39 am    Post subject: Reply with quote
Off Camber
PostPosted: Tue May 13, 2008 5:53 am    Post subject: Reply with quote
How about the BMW E30 Oil Cooler like this one
http://cgi.ebay.com/ebaymotors/BMW-e30-325-i-is-es-Complete-Oil-Cooler-Assembly_W0QQitemZ130220574017QQcmdZViewItem?hash=item130220574017&
Maybe you can adapt it to make it fit.
"Growing Old is Mandatory"
"Growing Up is Optional"
PostPosted: Tue May 13, 2008 1:32 pm    Post subject: Reply with quote
Why not consider a stock 931 cooler? They're compact (about 20x30x90cm), the hoses to run to the cooler are available, the conversion methodology is known, and I have one on a shelf in my basement
PostPosted: Tue May 13, 2008 1:59 pm    Post subject: Reply with quote
To answer your question (in the topic title): NO.
Now the long winded lecture...understanding of course that I'm no thermal dynamics expert. BUT...as I understand it...
Unless the manufacturer can provided documented and verified data, there is no way I'm going to believe that that design will dissipate enough heat away from the oil passing thru the tube. For any heat exchanger to work, the heated medium has to come into contact with some of the surface in order for the molecules to exchange heat. With that design, I think you'd get nothing more than a boundary layer around the perimeter of the tube with very little conductivity of heat from the hot oil [i]to[/] (and thru) the heat-sink like fins on the exterior of the unit. Just not a good or convincing design, IMO.
On the other hand, if the fins were inversed on the INSIDE of the tube such that the oil flowed past them, you might get more cooling effect. But I wouldn't waste my time on something like this. Just get a conventional cooler that is known to work and not really any more expensive than that unit.
As for space in the front of the car, I think there is PLENTY for you to play with. Here's how. Dropped my oil temps on the NA by 20-30° C.
Scorpio
PostPosted: Thu May 15, 2008 10:43 am    Post subject: Reply with quote
Ive got that part all sorted out!.. apologies in advance, couldnt help adding my own personal touch
my bonnet vent sent up from melbourne..xcuse the mess
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
Raceboy
PostPosted: Thu May 15, 2008 4:23 pm    Post subject: Reply with quote
I use E30 325 oil cooler on my 931 racecar.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
