78 Head and piston rings
blackhat
PostPosted: Mon May 05, 2008 12:45 pm    Post subject: 78 Head and piston rings Reply with quote
Hey all!
I've got a couple of odd ball questions for ya.
The first, I just bought a used '77 head w/ valves and springs (I'm not sure if it has the cam followers or not). I'm planning on sending that out to the machine shop to be gone over. When it's done, I'll just swap the head out with the one on mine. Well, that's the plan. What I'm curious about is, are the '77 and '78 heads interchangable? I checked the part numbers in the dc Auto catalog and they were the same for that year series I belive. If not, I'll have a head up for sale or trade right away. If they are, yay for me and I'll have a head up for sale/trade in the near future.
Second question.... Since I'll have the head pulled off in the near future and have access to the pistons.... bear with me, this is wear my crazy idea comes in.... can I pull the oil pan off, loosen the bolts for the rods and push the piston up and out to swap out the piston rings? I should be able to replace the rod bearings because they seem readily accessable but there's no point in doing a complete rebuild of the lower end considering its near to impossible to get main bearings. Does this seem feasable and sane? My goal is to not have to pull the engine out seeing as I don't have a cherry picker or engine stand yet.
EDIT
Also, is $25 + $25 for shipping ($50 total) a bad price for a head?
My First Porsche
1978 Porsche 924 N/A
Slam
PostPosted: Tue May 06, 2008 3:28 am    Post subject: Reply with quote
AFAIK, the heads are the same. I'd think $50 was a fair price for a head and shipping.
I'd also say good call on doing the rings when the head's off. It's not a crazy idea at all - but many here would advocate pulling the motor so the block can be sent out before new ring are put in. Much depends on the state of the bores. Regardless of the ring issue, doing the rod bearings may not be a bad idea. How many miles on the motor?
'84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
blackhat
PostPosted: Tue May 06, 2008 5:18 am    Post subject: Reply with quote
The mileage on the motor is unknown. Odometer stoped around 65K I belive.
What am I looking for in the piston chambers? My buddy said to run my finger around the edge of the piston chamber and see if there is a lip, if there is then the engine will have to be sent off. If there isn't, then just swap the rings.
What can I expect from replacing the rod bearings?
My First Porsche
PostPosted: Tue May 06, 2008 5:37 am    Post subject: Reply with quote
Do the rod bearings as well as the rings - they see worse wear than the mains.
Expect the valve guides to be done-for.
Make sure to get the valves lapped in, or do it yourself. For that matter, consider pricing out a performance valve job.
Also, measure the valves. Depending on if it's an early or late 77 head, the intake valves may be small compared to yours - cost power. Likewise the cam may be different. Interchangeable, yes; the same, not necessarily.
PostPosted: Tue May 06, 2008 2:00 pm    Post subject: Reply with quote
All 924 cylinder heads are not created equal.
A head from a 77 US 924 could be a Euro head with big valves, or it could be a US head with small valves, or it could be a late 77 cylinder head with other sized valves.
The head casting are different from year to year after 1977/2/
Some are better than others, because they breathe slightly better.
All are interchangable in most cases. It's just that some work better than others. Some years crack between (cylinders 2 and 3) more often that other years.
blackhat
PostPosted: Tue May 06, 2008 2:47 pm    Post subject: Reply with quote
Arg... Looks like I'll be picking up a gauge to measure the valves when the head gets here.
Best case scenario is it is the same head or better. Worst case, it is the pre-77.5 head and I'm SOL.
My First Porsche
PostPosted: Tue May 06, 2008 10:01 pm    Post subject: Reply with quote
Worst case it's a pre-77.5 head and you'd want to have the bigger valves installed. Though you could, if you were going to the expense, have your machine shop source BIGGER valves than the stock late ones, and use those for even better breathing...
RC
PostPosted: Tue May 06, 2008 10:40 pm    Post subject: Reply with quote
IIRC the exhausts are the same size. Inlet is 38mm on early US and 40mm on later US and Euro.
blackhat
PostPosted: Tue May 06, 2008 11:20 pm    Post subject: Reply with quote
Hmmm.... I wonder how much the guy would charge me for that..... How big could I get the valves up to on a stock cam? What's the largest you guys have seen?
Does that 2mm really make all the difference? I'm trying to squeeze everything out of her so if it is like 2HP, then that's a big enough loss for me to bring it back up to the 40mm or higher like 924RACR said.
My First Porsche
PostPosted: Wed May 07, 2008 12:32 am    Post subject: Reply with quote
I think the diff will be more than 2hp, and you need to do some research, look for the article Big Breather (was posted here a little while back) - Eurorace modded a head to put in even bigger than 40mm. Maybe 44?
They'd need to replace the seats, of course, as well as the valves themselves, and might want a little tweaking to the bowl "above" the valves to get clean flow.
Can't hurt to ask for a quote...
blackhat
PostPosted: Tue May 20, 2008 10:35 am    Post subject: Reply with quote
Sorry it's been a while since my last post but my daughter had her first birthday so it's been kind of hectic around here.
I finally got the head in. I don't have a gauge or micrometer here so I haven't gotten a chance to measure the valves so I'm not sure if they're 38mm or 40mm.
I'll be dropping it off at the machine shop to see what he can do for me. It looked straight but it's missing some of the intake and exhaust manifold bolts.
Does anyone know any 43mm valves that have the same dimensions as ours?
Also, will the 40mm valve just fit right in on the 38mm valve heads or will it require some machining?
My First Porsche
Chrenan
PostPosted: Tue May 20, 2008 12:05 pm    Post subject: Reply with quote
My big valve head from Euro Race (now European Motorworks). Valve sizes are 44mm Intake / 37mm Exhaust:
blackhat
PostPosted: Fri May 23, 2008 12:32 pm    Post subject: Reply with quote
Well, good news for me! I went out and bought a digital caliper today to measure the valves on my head and it appears that it has the 40mm valves on it. The scale actually said ~39.80 so I figured it was safe to say they're 40mm's. Yay for me!!
I'm going to ask my machine shop if he thinks he could do larger valves. If not, no biggy. I'm definately going to have him polish them and possibly a gasket match port job. Might as well I guess.
I'd love to do the Euro Race valve job but I definately don't have the $$$ for that.
Does anyone know where to buy aftermarket big valves that fit our heads?
My First Porsche
