Creeper Suggestions
PostPosted: Fri May 02, 2008 1:11 am    Post subject: Creeper Suggestions Reply with quote
I have this. . .uh. . .friend who's sorta big. He's not fat by any means, just big-boned. He weighs quite a bit.
My friend has a problem with creepers. The problem is that he destroys them. He tries to roll around under Sha. . .ermmm, his car. . .and the wheels bend and break off.
Can anyone recommend a creeper that is not an atrocious piece of shite?
My friend thanks you.
baldwin
PostPosted: Fri May 02, 2008 1:59 am    Post subject: Reply with quote
924 parts, http://verkopers.marktplaats.nl/10266983
'98 Volvo 940 LPT Estate
PostPosted: Fri May 02, 2008 3:38 am    Post subject: Reply with quote
http://www.bonecreeper.com/
Or
http://www.kreepster.com/
Or
http://www.gizmag.com/go/5933/
PostPosted: Fri May 02, 2008 3:43 am    Post subject: Reply with quote
I prefer foam pads to a creeper; lower profile, useable at the racetrack, easy clean up, comfortable on concrete especially when the concrete's cold. Just get the type they sell for kids to play on, or for ergo use at Sam's Club, Costco, etc...
PostPosted: Fri May 02, 2008 5:06 am    Post subject: Reply with quote
True, I have pieces of cardboard for that as well. Works great for oil changes since I don't have to jack the car(s) up to to it.
However for those of us who are shall we say less than spry, we need a little help getting in and out from under the car. Especially if you're doing it over and over again. You know, because you grabbed the wrong tools. Because you forgot a part. Because the wife called us back out to ask a question. Because the phone rang. Because the neighbor stopped by to see just what the heck you're doing. Because you got a piece of dirt or rust in your eye. Twice. Because you decide to get your safety glasses. Because you smacked your head and cut it open. Because you safety glasses have fogged up. Because you're either going to set the car on fire and role it out in the street or drink another beer....
I have a cheap creeper that basically pisses me off, for all the reasons the Bone was created for. For the most part it works fine for my 200lb butt. Now if I'd actually use it on the Porsche and not the Daily Drivers then maybe I could drive said Porsche!
Obviously keeping the floor and work area clean and tidy is important when working on a car. Routing drop lights, power tools, etc around a jackstand to keep the cords away from the wheels on the creeper helps a lot. Occasionally stopping and sweeping up the crap that has fallen off the bottom of the car helps the creeper roll, makes it easier to find the damned part you just dropped and heard bounce on the concrete, it also keeps less of that crap from getting on you or your clothes.
D Hook
PostPosted: Fri May 02, 2008 11:48 am    Post subject: Reply with quote
'80 924 n/a SOLD
agfisher
PostPosted: Fri May 02, 2008 10:46 pm    Post subject: Reply with quote
Best creeper I have ever seen/used. Awesome and comfortable. Built like it's going to be used in the space program.
Griot's Garage Creeper
1977 924 N/A Martini Edition
PostPosted: Sat May 03, 2008 1:42 am    Post subject: Reply with quote
Don? Don Gurney?
Why anyone would ever provide a smart-ass answer to a question of mine is beyond me. Seriously.
tuurbo
PostPosted: Sat May 03, 2008 1:56 am    Post subject: Reply with quote
A large piece of cardboard is best.
I broke my creeper too.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Sat May 03, 2008 2:11 am    Post subject: Reply with quote
I've found that a creeper is only useful if you can get the car up high enough to put it on 4-ton heavy duty jackstands designed for trucks or SUVs. I've noticed recently that my closeup vision is starting to go...anything closer than 6 inches, and I can't focus.
The foam pad trick Vaughan mentioned is ideal, although I usually resort to lying on the cold dirty concrete, or throwing down some cardboard.
PostPosted: Sat May 03, 2008 5:52 pm    Post subject: Reply with quote
I use old offcuts of carpet (Shaggy pile?! )
Cardboard is for Fords. Porsches deserve better!
(Oops! Was that too snobbish? )
