blackhat
Joined: 23 Apr 2008 Posts: 66 Location: Junction City, Kansas
Posted: Mon Apr 28, 2008 2:05 pm Post subject: Head gasket/head rebuild? |
Hey all,
You've probably seen me asking tons of questions about the head gasket and heads. This will be my first major repair job on a vehicle so I'm trying to soak in all the info I can before I undertake it.
My question to you all is, since the head is going to be off and I don't know when the last rebuild was, should I do a valve train rebuild?
I'm not entirely sure what all it entails. Is this something where if I bought the new springs, valve guides, and valves, I could just throw them in? I've heard talk about having to grind the valves down to match a specific height. Is this something more than a micrometer and a Dremel? Is this something a machine shop could do for cheap?
I figured I could look into it since the head will be off and the valves will be out for the valve seals.
Any thoughts and advice would be great! _________________ My First Porsche
1978 Porsche 924 N/A |
Posted: Mon Apr 28, 2008 3:13 pm Post subject: |
I haven't paid for a "carry-in" valve job in a while, but last time I did it was quite cheap at the machine shop. Probably not a job you want to cut your teeth on without supervision! _________________ Toofah King Bad
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Mon Apr 28, 2008 3:28 pm Post subject: |
The key is finding a good machine shop. They will be able to tell the condition of the springs , guides , straigtness ect. Grinding or lapping the valves and seats is common and not expensive. No need replacing parts that still have life.
Ask around, find a shop that does good honest work and you are set.
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
Martijnus
Posted: Mon Apr 28, 2008 8:27 pm Post subject: |
if the valves aren't bent, they can be cleaned. If they have some minor damage on the sealing surface, they can be machined, making the seal like new.
If that should occur, the valve seats (which are the most common 'repair') should be taken care of. That just involves cutting the seats, which causes the valve to sit deeper in the head, so the valve stem needs to be shortened too.
The guides could be worn out, those are hard to get over here, but maybe in the US it's not a problem. Won't take much time, so costs less
If the valve seats are damaged too much to cut them, they need to be replaced. The material costs are low on that.
After all that work has been done, the head gets flattened (how do you call that?) so that the gasket won't leak.
Most of the costs is in labor, material isn't that much.
Just find a rebuilding shop which takes a look at the head and can specify what needs to be done. In most cases, all mentioned above is NOT necessary. If the valves seal the ports well (vacuum test) there is no need to clean the valves, cut the seats and so on...
Luckily it's an 8valve head... 16v costs way more  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
blackhat
Posted: Mon Apr 28, 2008 8:50 pm Post subject: |
Awesome! Thanks for the advice! I'll be calling the machine shops today and some various auto guys to see if they would suggest one. _________________ My First Porsche
Posted: Mon Apr 28, 2008 11:43 pm Post subject: |
| Martijnus wrote: | | After all that work has been done, the head gets flattened (how do you call that?) so that the gasket won't leak. |
We call it skim-cutting or cleaning the head deck. Usually no more than .001" or so provided the head isn't warped.
blackhat, as you're looking around for a local machinist, I would urge you to find a shop that has experience specifically with aluminum heads. If you have a top notch race shop in the area, that would do, provided they have experience with later style small blocks, turbos, imports, or aluminum components. I use a local shop called Holbert Racing that is top notch...I pay maybe 10% premium for their services, but it's worth it because they know their stuff, and I can drop in, ask questions, and chat pretty much whenever I want, which can be invaluable.
Alternatively, you can look for a shop that specializes in VW's or Audi's of the same era. Don't tell 'em it's for a Porsche until they've given you a firm quote...tell 'em you have a VW head you want to have reconditioned.
If you *really* want to go all out, you can send your head to European Motorworks in Cali. They specialize in our cars, and have specific builds for the 924. This is where I'll be sending my head in May for my UWB project. Call them and ask for Jorge (they're not very good about responding via email).
One thing to be aware of is that if the valve guides need to be replaced, you want it to be done by a shop that knows what they're doing. The guides are relatively soft brass, and if the machinist just tries to press them out, they can flatten the ends and foobar the head. The end of the guide should be gournd off, and then the remainder should be pressed out from there to avoid damaging the head. _________________ erstwhile owner of just about every 924 variant ever made |
Chrenan
Posted: Tue Apr 29, 2008 12:20 am Post subject: |
I'm with Dan. Call Jorge at European Motorworks, then pack up your head with a $1000 bill and have them go to work on it. They've been tuning these cars since the 1980s when they were called Euro Race. Best money you'll spend on a normally aspirated 924 engine is the big valve head conversion, trust me. _________________ 1987 951 - M193 Version for Japan |
dpw928
Posted: Tue Apr 29, 2008 2:39 am Post subject: |
If you are close to Tulsa, OK Gary Robinson knows Porsche heads and he is very reasonably priced. I've used him for both the 928 and 924 heads and it's never cost more than $200 for a rebuild. If interested, let me know and I'll get his phone number for you.
78 928 5 sp Silver
78 928 AT Euro Black |
924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Thu May 01, 2008 5:14 pm Post subject: |
i dont know shit about cars so.....
i recently did a rebuild on my head and i had a bent valve, blown head gasket, i mean it was crazy in there!
i had this mexican mechanic who took my head out and took it to a machine shop and came back and installed it in about a week, took another weak to tune that #### and find all the leaks but we finaly finished today and all it costed was $850 TOTAL including labor... i was pretty impressed
still slow is fuk.... a bit faster tho a mom with all her soccerr team kids in her van would probably beat me but i still love my 924 and ive owned several cars but i will never sell this one! _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
