30MM Torsions, Which Springs?
PostPosted: Wed Apr 23, 2008 7:21 am    Post subject: 30MM Torsions, Which Springs? Reply with quote
I'm thinkin' 250, what do you guys think?
(For Shaggy)
Chrenan
PostPosted: Wed Apr 23, 2008 7:33 am    Post subject: Reply with quote
Maybe a little higher? Effective rate of a 30mm torsion bar on a 924 is 335 lbs. Unless they are hollow, then it is 292 lbs.
PostPosted: Wed Apr 23, 2008 8:36 am    Post subject: Reply with quote
That's quite low - I ran 400, 350 might also suit you.
PostPosted: Wed Apr 23, 2008 9:03 am    Post subject: Reply with quote
Hmm, I guess I should also ask whether I will hate the ride quality of the 30s!
PostPosted: Wed Apr 23, 2008 9:58 am    Post subject: Reply with quote
I found them to be a bit soft...
...on the track!
John Brown
PostPosted: Sat Apr 26, 2008 11:12 pm    Post subject: Reply with quote
400 is my recommendation also. And, yes you will (hate the ride quality).
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Sat Apr 26, 2008 11:47 pm    Post subject: Reply with quote
400 = no street ride quality and loose teeth.
PostPosted: Sun Apr 27, 2008 1:29 am    Post subject: Reply with quote
400 wont be that stiff. I have driven a 931 with 700 at the front. That was pretty stiff, a bit to much for a street car. Harsh ride quality is mostly due to the damper stetup.
PostPosted: Sun Apr 27, 2008 1:39 am    Post subject: Reply with quote
How are the roads in Sweden?
Over here this is normal:
Vince Ponz
PostPosted: Sun Apr 27, 2008 3:03 am    Post subject: Reply with quote
WOW, you still have dinosaur footprints in your town.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
-nick
PostPosted: Sun Apr 27, 2008 3:41 am    Post subject: Reply with quote
We've got dinosaurs in Boston too
I ran 25.5mm rear bars with 200# front springs on a '77 and I felt it was not pleasant on city streets. It was a couple hundred pounds lighter than a 931, but 400# & 30mm would be torture in any model.
Right now I'm running 200# fronts with the stock 23.5 torsions with bilsteins and I feel like it's just the right balance between pleasant in the city and responsive in the turns. Just food for thought.
1980 931S
1991 964 C4 Cabriolet
PostPosted: Sun Apr 27, 2008 1:19 pm    Post subject: Reply with quote
Ugh, there are NO roads that look like that around here. Seldom freezes, temperature variations are quite low compared to other places.
I'm goin for it.
PostPosted: Sun Apr 27, 2008 2:03 pm    Post subject: Reply with quote
Shaggy will become a one driver car.....
Splineless
PostPosted: Sun May 18, 2008 1:06 am    Post subject: Reply with quote
I'm just across the river from you and was wondering about which bars to use with 200# springs I just bought. I was thinking I'd have to go thicker for balance. Glad to hear from someone with 1st hand experience. I'll stick with what I have - just need a pair of Bilsteins. Thanks.
