disconnecting the powersteering
frankros924
PostPosted: Fri Apr 25, 2008 3:46 am    Post subject: disconnecting the powersteering Reply with quote
Hi,
does anybody know how to disconnect the powersteering.
I have a 1987 924s automatic.
thank you.
bcblase
PostPosted: Fri Apr 25, 2008 4:20 am    Post subject: Reply with quote
Just disconnect the lines at the rack and let the fluid drain out, then disconnect the power steering pump (take the belt off). It will work in manual mode, but it will be really hard to turn the steering wheel while at a standstill (I know from experience).
I believe the tie rods are a little beefier on the manual racks to handle more stress, but I know a few people that run their 'S' with the PS disconnected.
They make replacement manual rack kits from the early 944 that fit - the full conversion kits are about $950. I have it on my "to do" list for this coming winter. I'm tired of ATF dripping all over the place.
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
MrMoMo
PostPosted: Fri Apr 25, 2008 9:53 am    Post subject: Reply with quote
Or just take the belt off...
Bruce
'87 924S (project 937)
'87 924S parts car
'87 924S parts car
-Strewn amongst the other vehicular mass engulfing my property!
PostPosted: Fri Apr 25, 2008 10:31 am    Post subject: Reply with quote
BC, you could also fix the leaks. . .
bcblase
PostPosted: Fri Apr 25, 2008 2:05 pm    Post subject: Reply with quote
About the Leaks - I think part of the problem is that the PO used a bunch of regular hose clamps that have grooves that dig into the hoses and cause some of the leaks. Tightened the hose clamps only works temporarily.
Do they still make the solid hose clamps that came from Porsche?
BC
PostPosted: Fri Apr 25, 2008 2:19 pm    Post subject: Reply with quote
They do. . .I can tell you the company name tomorrow, as the things are all over my car and ungodly expensive. I'd love to find another supplier (other than PCNA).
JSilverman
PostPosted: Fri Apr 25, 2008 10:56 pm    Post subject: Reply with quote
PS leaks in these cars are expensive fixes. Plus theyll probably leak again eventually so I bought a used manual rack. Paid $120 for it, needed new tie rod ends @ $16 each. Just finished bolting up the rack yesterday, cant wait to take my leak free steering system for a test drive.
Point of advice when removing the PS rack: If you have allen head banjo bolts dont bother using an allen wrench to remove them, youll just strip them all. I would just go right for a pair of channel locks to remove the banjo bolt from the rack.
