frankros924
Joined: 14 Sep 2007 Posts: 29 Location: Sacramento California
Posted: Fri Apr 25, 2008 3:46 am Post subject: disconnecting the powersteering |
Hi,
does anybody know how to disconnect the powersteering.
I have a 1987 924s automatic.
thank you. |
bcblase
Posted: Fri Apr 25, 2008 4:20 am Post subject: |
Just disconnect the lines at the rack and let the fluid drain out, then disconnect the power steering pump (take the belt off). It will work in manual mode, but it will be really hard to turn the steering wheel while at a standstill (I know from experience).
I believe the tie rods are a little beefier on the manual racks to handle more stress, but I know a few people that run their 'S' with the PS disconnected.
They make replacement manual rack kits from the early 944 that fit - the full conversion kits are about $950. I have it on my "to do" list for this coming winter. I'm tired of ATF dripping all over the place.
BC _________________ 1987 Porsche 924S - track toy
MrMoMo
Joined: 14 Mar 2007 Posts: 60 Location: Kingston, Ontario
Posted: Fri Apr 25, 2008 9:53 am Post subject: |
Or just take the belt off...  _________________ Bruce
'87 924S (project 937)
'87 924S parts car
'87 924S parts car
-Strewn amongst the other vehicular mass engulfing my property! |
Posted: Fri Apr 25, 2008 10:31 am Post subject: |
BC, you could also fix the leaks. . . _________________ Toofah King Bad
bcblase
Posted: Fri Apr 25, 2008 2:05 pm Post subject: |
About the Leaks - I think part of the problem is that the PO used a bunch of regular hose clamps that have grooves that dig into the hoses and cause some of the leaks. Tightened the hose clamps only works temporarily.
Do they still make the solid hose clamps that came from Porsche?
Posted: Fri Apr 25, 2008 2:19 pm Post subject: |
They do. . .I can tell you the company name tomorrow, as the things are all over my car and ungodly expensive. I'd love to find another supplier (other than PCNA). _________________ Toofah King Bad
JSilverman
Posted: Fri Apr 25, 2008 10:56 pm Post subject: |
| Rasta Monsta wrote: | | BC, you could also fix the leaks. . . | PS leaks in these cars are expensive fixes. Plus theyll probably leak again eventually so I bought a used manual rack. Paid $120 for it, needed new tie rod ends @ $16 each. Just finished bolting up the rack yesterday, cant wait to take my leak free steering system for a test drive.
Point of advice when removing the PS rack: If you have allen head banjo bolts dont bother using an allen wrench to remove them, youll just strip them all. I would just go right for a pair of channel locks to remove the banjo bolt from the rack. |
